Results 1 to 6 of 6
    Junior Member
    Judd3rman's Avatar
    Feb 2016
    1
    Handbrake cable!!!
    Hey guys, without the use of a Haynes, im not sure if this job is a bit of a bugger or not?
    But yes, the handbrake cables went PING! I have a replacement from our friends at GSF, so the big question is, how does one fit this?
    If its too mental of a job, is it best to let a pro at it?
    Cheers,
    Scotty
    Do not underestimate your inability to attract women.
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Impossible to answer as we don't know your capabilities!
    Only you can answer that.
    If you've never done handbrake cables before of even touched rear brakes, then I'd advise you leave it to an expert. Safety first ....and all that.
    You really need the car in the air to make it easy for yourself, otherwise your laying on your back alot. Both rear brake assemblies will need stripping out and part of the transmission tunnel inside the car, may need removal to access adjustments.
    we need more clues though (I hate guessing )....What car is it?
    Junior Member
    Judd3rman's Avatar
    Feb 2016
    1
    Sorry Lee, I went into total 'tard mode
    2005 S40 20 D se
    Aug 2008
    Lockerbie, SW Scotland
    2
    My haynes says you need to disconnect exhaust under car to get it out the way, remove heat shield to get at the cables.
    62' V60 D3 R Design
    62' V60 T6 AWD R Design polestar'd
  5. #5
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by Timo. View Post
    There you go then.......a job for a four post lift!
  6. #6
    Junior Member
    Judd3rman's Avatar
    Feb 2016
    1
    Thanks gents, will look up a friend in the BH area to borrow a lift
Tags for this Thread
