After some spirited uphill driving, got a misfire and grey smoke. I pulled the main HT lead and cranked it and it sounded uneven. Also whilst running, noticed some oil smoke coming up from the rear of engine around the centre. I suspect a leak on cylinder 3 as the engine is least affected when that lead is pulled. Given the oil smoke from the back of the engine, I think it may be the head gasket.
At the moment I'm on holiday in Somerset and I need to get back to Warrington on Friday.
I have some questions which people might be able to help with.....
- Can I drive this around with the injector disconnected on cylinder 3? Will it cause damage to anything?
- This is going to take me a while to fix as I can only spend evenings and weekends on it, and I need a car whilst it's out of action. What do people normally do in this situation ?
Cheers for any advice.
C
