Afternoon all,
As part of my ongoing 'change all the fluids schedule' for my 850 T5, I'd like to remove and replace the PAS fluid.
I've trawled through a number of archive threads and started to confuse myself with exactly what I need to order to change/refresh my PAS fluid... saw quite a lot of mention about using ATF 3, but then other threads saying specialist fluid is needed?
I am working away in France so can't check my manual, but will be back in 2 weeks time and am hoping to order the required fluid to ensure a change can be done on my return, I know I have to use a syringe and remove as much as possible of the old from the reservoir, then top up and repeat, whilst turning lock to lock - Just need the correct fluid (unless I've missed something)...
Thanks in advance.
