Results 1 to 5 of 5
Thread: V70R handbrake
    Member
    probably on the net reading
    about volvos
    Jan 2013
    aberdeenshire
    11
    V70R handbrake
    Afternoon,
    looking for some guidance on handbrake shoes.
    recently changed all the shoes and cables. Seemed to take all the adjustment to get a bite but it passed the MOT. now that the linings are worn slightly there doesnt seem to be enough to adjustment to get it to bite.
    Had it all apart and back together twice now and the only thing we can come up with is that the shoes are the wrong diameter, the info on gsf says 180mm which is what i have fitted. the discs are nearly new so no issues with that inner diameter.
    Anyone else had any handbrake shoe issues with the v70r brembos?
    Cheers
    Member
    about volvos
    Jan 2013
    aberdeenshire
    11
    Problem solved,
    replace the standard H spacer with the adjustable H spacer!
    Always wondered why there was no shoe end adjustment.
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by seadog850r View Post
    Afternoon,
    Cheers
    Are you sure you've fitted the right shoes? I don't trust sites like GSF, ECP etc...their info is ALWAYS incorrect!
    You should have fitted OE mate for the shoes.
    Regards the Brembo's.....No, I've not had issues. Adjust up perfectly and work perfectly. Two clicks of the hand brake and she holds, 3 clicks on a hill, 4 clicks and the car may aswell be bolted to the floor!
    I'm using OE shoes, Brembo drilled discs and Brembo pads.
  4. The Following User Says Thank You to LeeT5 For This Useful Post:
    jamesy12345 (Tuesday 26th January 2016)
  5. #4
    BigGreg's Avatar
    Dec 2015
    90
    ����������bolted to the floor. Love it ������������
    V70r 6Speed Auto
    First car to put a smile back on my face for years!
  6. #5
    Member
    about volvos
    Jan 2013
    aberdeenshire
    11
    Quote Originally Posted by LeeT5 View Post
    I'm using OE shoes , Brembo drilled discs and Brembo pads.
    Got another set of shoes from Volvo when i picked up the adjusters last night, had a quick look and dimensionally they are the same as the GSF ones, The shoe lining might be a different compound.
    Will get the adjusters fitted tonight.
    Cheers
