AFAIK you'll need the dealer to code the subwoofer mate, it's part of he carconfig in the CEM module, iirc it needs to open a relay in the REM.
V70r 6Speed Auto
First car to put a smile back on my face for years!
Paul,S60r (Thursday 4th February 2016)
If the car is cable equipped then it will just plug in and work, like Harvey says.
Regards IPDs utube channel, lol! Get your car sorted, code free and 'stage 0' ready, before you even think about modding mate. Live with it for 6 months and get used to it. Learns its niggles and iron out any faults, nipping them in the bud before they escalate. If you want to enjoy your R and keep on top of it....learn to listen to it ;-)
BigGreg (Friday 29th January 2016)
Yup, as said above, do not attempt any performance mods, before the car is at stage 0.
Make sure all filters, oil, spark plugs, ignition coils, fluids in gearbox, Angle gear, rear diff, AOC, replaced, then your DEM and propshaft + bearings have no issues.
After that check Fuel line, Fuel pump(duty cycle), FPS, PEM, Injectors. Check the PCV system, TCV, MAF and vacum lines are in order, no leaks and work as should.
Afrer these, I would check the suspension parts, engine mounts etc.
SOLD - 2004 Volvo V70R GT/Titanium Gray/Gobi - 103000 Miles, Bilstein B6 Front, Resonator delete, do88 Intake, do88 Lower Intercooler pipe, Forge CBV with green spring, Grey Pierburg TCV, Viva Strut Bar Conversion Kit, 17'Pegasus, 235/45/17 Goodyear Eagle F1 AS3
V70r 6Speed Auto
great you are happy ,now to adjust the Bass untill your happy, little knob on amp on sub.
V70r 6Speed Auto
Nice one!
The circular indentation below the label has a circular knob with bolt that screws down into a captive nut on a metal bracket. Stops it rattling.
BigGreg (Monday 1st February 2016)
Just use a 40mm long 6mm diameter threaded bolt with a large flat washer.
Well just dropped car at Murray Volvo and I have to say they did not fill me with confidence when I explained what LeeT5 and I wanted them to check. But he took loads of notes and said they would try. So now awaiting the phone call.
Sub not rattling at the moment, jack was wedged behind it. That will do until I come across some 6mm threaded rod.
V70r 6Speed Auto
Nice! Congrats! Btw where did you get the sub?
Nice catch! Definitely on my list for the future.
So got car back today from Murray Volvo Edinburgh. They investigated Sat Nav issue and diagnosed RTI box as faulty (Leet5 will need a chat), they confirmed my software for the suspension was the latest version and recalibrated it. Checked level sensors (by disconnecting), bushes and front shocks and found all to be ok. So I was happy enough with that, the RTI will now be removed and sent to Lee's contact for fixing. Then I can go about installing the Imiv and Bluetooth when up and running. Before I left I ordered the jack holder, new screw anchor for space saver and the strap for the jack holder. They are even going to post out to me to save me going back in to fetch. Shame I had to be so persistent with old parts chap, told me there was no Sub option on a V70 hence why he could not find the bits I wanted. Ten mins later he declared "never seen that before" !!!!!!
V70r 6Speed Auto
You didn't take the numbers I listed then. the parts in my local dealer is over the service counter, but the parts guy just says go around to the Trade counter and he sorts out what I want he even remembers the cars reg now.
http://www.vpcuk.org/forums/showthre...l=1#post747306
Just remember the jack holder doesn't fit you will be there for a bit cutting it down to size .just be careful as the foam is quite hard to trim to size.
[QUOTE=Harvey;796068]You didn't take the numbers I listed then. the parts in my local dealer is over the service counter, but the parts guy just says go around to the Trade counter and he sorts out what I want he even remembers the cars reg now.
Sorry Harvey, was going to order from FDF but when I was there it seemed the right thing to do. Guy was ok, asked me through the back in to the stores while he struggled on the PC. To be fair I think he would have been much quicker with old style microfeesh thing. But done now. But away tomorrow to London till Tuesday so all on hold till then. Had a blast down to Dunbar this afternoon 120miles round trip, wife pipes up I think you love this car more than you love me. I couldn't answer!!��
V70r 6Speed Auto
