Results 1 to 9 of 9
Thread: Obd1
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Obd1
    Can I run a OBD1 flywheel with sensor on a M4.4 ecu ?
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    From memory it all depends on what signal the ecu is wanting to receive gav had lots of problems on 4.3 swapping a later fly wheel into his obd1 car and it wouldn't fire correctly.
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    P.s he also tried later sensors which didn't work so ide put money on it to use a later fly wheel if your running 4.4
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    I've checked the ecu info for both OBD1 & OBD2 and both have a crank sensor output of 825Hz @1.5v
    The reason I asked coz I just got hold of a OBD1 engine.
  5. #5
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    That's why I said it's the ecu not the sensors
  6. #6
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    I think the sensors are the same, I read a Volvo tech article not long ago which states that when fitting the later flywheel the wires in the sensor connector have to be switched round (must be a polarisation issue).
    My 850 runs M4.4 and has the older flywheel (I think, it's the one with the holes in)
  7. #7
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Quote Originally Posted by Dangerous Dave View Post
    Gav tried that with switching the wires but he still had intermittent starting issues and only thing to correct it was to change to the correct flywheel
  8. #8
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The flywheel on the engine I've just picked up has holes in the out side of the flywheel and it OBD1
    While the flywheel in the 850 has slots and is using a M4.4
  9. #9
    New Identity
    Dec 2006
    West Midlands
    2,491
    Hmmm, not sure then. I don't remember reading anything about the crank sensor being an issue on the VS thread (or the m44 wikia) when converting from M4.3 to 4.4
    Here is the tech article:
    https://www.dropbox.com/s/aze843njd1...tions.pdf?dl=0
