Morning all,
Giving the R a bit of a suspension, brake and wheel refresh and cleverly managed to split the offside shaft when removing the hub. After a couple hours of swearing and chasing ball bearings about the shed floor finally got the shaft together, re greased and new boots fitted. it seems to be pure fluke if the bearings locate together!
Does anyone know if mk1 focus ST drive shafts are the same? i'm sure i read somewhere the grearboxes are the same? a friend has a new unused set at his work i can use but i thought i'd ask here before taking mine apart again.
Cheers
