Results 1 to 20 of 20
Thread: Piston help
    Sep 2005
    Truro, Cornwall
    168
    Piston help
    I am needing to change the rings on my 850 t5, I heard some rings aren't available depending on what Pistons I may have, question is are there better standard t5 pistons available eg v70 ones? That rings are available for?
    Sep 2005
    Truro, Cornwall
    168
    Anyone with piston experience?
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    For the 850 block your best bet will be to get the mayle oversized pistons and rings to match these are more than good enough for decent power.
    Sep 2005
    Truro, Cornwall
    168
    Thanks Pete. Do you know where I get these from?
  5. #5
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    I believe volvo still sell them but when I did mine the machine shop got them and they were better priced than volvo aswell
  6. The Following User Says Thank You to t5 pete For This Useful Post:
    mike 850 (Sunday 13th December 2015)
  7. #6
    Sep 2005
    Truro, Cornwall
    168
    Awesome, in the middle of pulling the block out so when I take it to the engineer I'll see what he says, thanks for your help. Out of curiosity are you running higher power? I'm looking at about 400bhp so don't want inferior pistons if they can't cope, did you manage to get good quality ones? Cheers
  8. #7
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    They will be good for 400 I'm currently running some where between 300 and 350.
    Other options is wiseco forged pistons but the general rule of thumb is the standard pistons are pretty good
  9. The Following User Says Thank You to t5 pete For This Useful Post:
  10. #8
    Nov 2013
    203
    I was going to say, I thought the stock stuff is more than capable at that power, it's the rods that struggle.
  11. The Following User Says Thank You to Sweep For This Useful Post:
  12. #9
    Sep 2005
    Truro, Cornwall
    168
    Quote Originally Posted by Sweep View Post
    I have forged rods, it's not to handle but I have low compression so need to sort the rings out, if I need oversized or if I have to change the pistons due to rings not being available I might go forged as it probably isn't going to cost much more, I need to see how worn the block is first.
  13. #10
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    The mayle pistons runs about 100 each with pins and rings
  14. The Following User Says Thank You to t5 pete For This Useful Post:
  15. #11
    Sep 2005
    Truro, Cornwall
    168
    The oversize ones? Forged ones look about £550 plus postage from states, emailed a couple of places to get a price, customs on top, not really sure which way to go yet, guess I need to wait and see what wear there is first
  16. #12
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Yes that's for over size search on part box they wil have wiseco and uk supplier so no charges
  17. #13
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
  18. The Following User Says Thank You to t5 pete For This Useful Post:
  19. #14
    Sep 2005
    Truro, Cornwall
    168
    https://re-volvparts.com/store/home/...-ke155m81.html
    That converts roughly to 560, no idea on postage and customs, probably wait a month for not much saving I think? I think I'll stick to the mahle ones, do you know where you get them for 100 each? From Volvo?
  20. #15
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Y machine shop sourced them ask the guys who's doing your re bore to get a price on pistons and shells also take your crank in to match shells
  21. #16
    Sep 2005
    Truro, Cornwall
    168
    The rods were fitted last year, that side is ok I was stupid and didn't do a compression test done or check that out so its my fault, rods, crank etc are all good.
  22. #17
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Ah that's good news then just a case of a re bore and a new set of pistons I would imagine
  23. #18
    Sep 2005
    Truro, Cornwall
    168
    Yeah, fingers crossed
  24. #19
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    I'm running 22 psi at 353 bhp on stock internals.
  25. The Following User Says Thank You to oblark For This Useful Post:
  26. #20
    Sep 2005
    Truro, Cornwall
    168
    I bent rods at about 320bhp, are you not running me7 or was that just the top half?
