Results 1 to 17 of 17
    Dare to be Different
    vinny is getting a
    revamp....be back soon
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    850 t5 won't start
    have just finished putting engine back together after a manifold and turbo upgrade and now it won't start.
    turns over well, have spark, but fuel only dribbles from fuel rail when valve depressed.
    i also changed the alarm relay as the alarm was playing up.
    my question is does the immobiliser cut the fuel or the starter/ignition?
    does the relay need coding (i have the matching remote from the same car.)?
    or could it just be the fuel relay?
    any help/suggestions greatly appreciated
    "dare to be different"
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    can you hear the pump priming? I think if it's the immobilizer the car will start for a second or so then die.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    first check the main relay on the top of the rad, tripped me up for ages when I had a similar sounding issue, wires corrode real easily around there, get someone to crank it over and wiggle the wires, that relay does control the fuel pump, so possible
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    awesome, thanks guys, i'll try these tomorrow and report back.
  5. #5
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    Quote Originally Posted by claymore View Post
    couldn't hear it, but there was some fuel in the rail. the rail must have been empty as it has been disconnected for ages.
  6. #6
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by t5steve View Post
    I was still getting some pressure at the rail but still wouldn't go, spark and everything else was there, and the final reason was corroded wires to the main relay, gone like a trooper after sorting that, till the pump gave out many years later (similar symptoms no surprise),causing 2 of the 3 tow homes in over 8 years can't be too bad for a 20 year old car
  7. #7
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    Quote Originally Posted by MoleT-5R View Post
    i'll be checking this in morning. many thanks
  8. #8
    Mr Sheen's Avatar
    Jul 2008
    Fife
    28
    Check the cam position sensor.
  9. #9
    Jul 2008
    Red Lodge
    11
    alarm relay & immobilizer are not linked....
    alarm relay will stop the starter engaging
    Immobilizer sends a pulsed signal to the ecu to wake.... not entirely sure how it allows the car to fire & then die but as claymore says that is what seems to happen...
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=2552&dateline=1218822  313
    She may not be perfect but i love her anyway....
  10. The Following User Says Thank You to PNuT For This Useful Post:
    Dangerous Dave (Tuesday 8th December 2015)
  11. #10
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    well "vinny" has come alive again............turned out to be the fuel pump had dried out and stuck.............a couple of taps on the bench and it began working......i have changed it now (i had a spare that was ok) and vinnyroars at the turn of the key............a big thanks to flyingbrick who came and changed turbo for me last week...........now on with the paintwork.............thanks guys for all your helpful suggestions
  12. The Following 2 Users Say Thank You to t5steve For This Useful Post:
    MoleT-5R (Wednesday 9th December 2015),theflyingbrick (Wednesday 9th December 2015)
  13. #11
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    How did the turbo turnout? Ok
  14. #12
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    Quote Originally Posted by Ettienne View Post
    yes turbo is fine, no smoke and no leaks
  15. #13
    Member
    mr marshalltown's Avatar
    Sep 2015
    shildon county Durham
    2
    Good work getting it sorted I must admit my car was stood for a while with a dry tank and I'm sure the pump runs louder now than it used to
    and when i read this thread about it im lucky it didn't seize up aswell i would prob never give it a second thought
    by the way out of intrest what turbo did you upgrade to and has it made a big difference in performance just I'm looking to upgrade and any advice or info i could get would be much appreciated ☺
  16. #14
    Trader
    Kingsford G's Avatar
    Nov 2011
    Colchester,Essex
    1,352
    Well done mate.R u changing the colour of doing something else?
  17. #15
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    Quote Originally Posted by mr marshalltown View Post
    just a small upgrade from 15 to 16. havn't had it on road yet, i'll let you know when it's back on road
  18. #16
    vinny is getting a
    t5steve's Avatar
    Jun 2011
    laindon, essex
    427
    Quote Originally Posted by Kingsford G View Post
    yes complete change,lots of body mods, still white but now pearl white inside and out, with a bit of pearl yellow as well.
    will be bringing it to ace cafe in march so come have a look.
  19. #17
    Trader
    Nov 2011
    Colchester,Essex
    1,352
    Interesting,the is better be out to show the best of it that day lol
