I read (and clear) the ignition codes using a an LED and resistor connected to pins 3,(5) and 16 to the ODBII port as per this diagram:
from JODT5 on volvo forums http://www.volvoforums.org.uk/archiv...p/t-42315.html
connect a wire from the + out feed port, number 16 securing the wire into the port with a paperclip, to a 12volt led......ignore the in line resistor in the picture
connect two wires to the other port of the led....connect one lead to port number 3, again a paper clip will be usefull....
with the ignition off the light should illuminate
turn the key to pos II and the light will go out.....
the next step, with key at pos II is to dip your spare wire into port number 5 for a couple (2/3) seconds..., your lamp will illuminate...after a couple of seconds remove the wire from port number 5 and watch the lamp....
it may take a few tries to read the flashes as there will be a pause between each digit for you to record....
for instance the normal, nothing wrong code is
flash.........flash.........flash........
the code for 1-2-3 is
flash.........flash....flash............flash..... flash.....flash.....
it will become obvious when you see it........
to delete any codes insert the port 5 wire for FIVE second and remove and wait...after a moment or two the light will flash, immediately and before the light goes out reinsert the wire to port 5 for another 5 seconds..., this may need to be done several times before you get the hang of it.....
by moving the wire from port number 3 to port number 6 and carrying out the same proceedure you can check your climate control ecu
by moving the wire from port number 3 to port number 13 and carrying out the same proceedure you can check your cruise control ecu although you will have to drive the car over 20 mph and not removed the key before you check this, ie to turn off the car turn to position I and then back to II
Codes:
1-1-1 No faults.
1-1-2 ECU.
1-1-3 Fuel injectors.
1-1-3 Heated Oxygen sensor-max enrichment sensed (94-up).
1-1-5 Injector #1.
1-2-1 Mass airflow sensor.
1-2-2 Air temp sensor signal.
1-2-3 Coolant temp sensor signal.
1-2-5 Injector #2.
1-3-1 Ignition system RPM signal.
1-3-2 Battery voltage.
1-3-3 Throttle switch signal (idle).
1-3-5 Injector #3.
1-4-2 ECU faulty.
1-4-3 Knock Sensor signal missing or defective.
1-4-4 Fuel system load signal(missing or defective).
1-4-5 Injector #4.
1-5-3 Rear heated oxygen sensor signal.
1-5-4 EGR system-leakage or excessive flow.
1-5-5 Injector #5.
2-1-2 Oxygen sensor signal(front sensor on 94 and later models).
2-1-3 Throttle switch signal.
2-1-4 Ignition RPM signal erratic.
2-2-1 Heated Oxygen Sensor(Rich mixture/part throttle).
2-2-2 Main relay.
2-2-3 Idle valve signal.
2-2-4 Coolant temp sensor signal.
2-2-5 A/C pressure sensor signal.
2-3-1 Lambdfa adjustment.
2-3-1 Heated Oxygen sesnor(lean mixture/part throttle) 94-up.
2-3-2 Lamda adjustment.
2-3-2 Adaptive heated O2 sensor control (94-up).
2-3-3 Idle valve-closing signal.
2-3-4 Throttle switch signal missing.
2-4-1 EGR malfunction.
2-4-5 Idle air control valve-closing signal.
3-1-1 Speedometer signal.
3-1-4 Camshaft position signal missing or defective.
3-1-5 EVAP emission control system.
3-2-1 Cold start valve-signal missing.
3-2-2 Airflow meter hot wire.
3-2-4 Camshaft position siganl erratic.
3-2-5 ECU memory failure.
3-3-5 TCM request for MIL.
4-1-1 Throttle switch signal faulty or missing.
4-1-3 EGR temp sensor signal incorrect or missing.
4-1-4 Turbo boost regulation.
4-1-6 Turbo boost reduction from TCM.
4-2-5 Temp warning level #1.
4-3-1 EGR temp sensor faulty or missing.
4-3-2 High temp warning inside ECU.
4-3-3 No rear knock sensor signal.
4-3-5 Front heated oxygen sensor - slow response.
4-3-6 Rear heated oxygen sensor compensation.
4-4-3 Catalytic converter efficiency.
4-4-4 Acceleration sensor signal.
4-5-1 Misfire - #1 cylinder.
4-5-2 Misfire - #2 cylinder.
4-5-3 Misfire - #3 cylinder.
4-5-4 Misfire - #4 cylinder.
4-5-5 Misfire - #5 cylinder.
5-1-1 Adaptive oxygen sensor control-lean mixture at idle.
5-1-2 Oxygen integrator at max lean running limit.
5-1-3 High temp warning inside ECU.
5-1-4 Engine cooling fan-low speed signal faulty.
5-2-1 Oxygen sensor preheating-front.
5-2-2 Oxygen sensor preheating- rear.
5-3-1 Power stage-group A.
5-3-2 Power stage-group B.
5-3-3 Power stage- group C.
5-3-4 Power stage- group C.
5-3-5 TC control valve signal.
5-4-1 EVAP valve signal.
5-4-2 Misfire - more than one cylinder.
5-4-3 Misfire - at least one cylinder.
5-4-4 Misfire - more than one cylinder/catalytic converter damage.
5-4-5 Misfire - at least one cylinder/catalytic converter damage.
5-5-1 Misfire - #1 cylinder/catalytic converter damage.
5-5-2 Misfire - #2 cylinder/catalytic converter damage.
5-5-3 Misfire - #3 cylinder/catalytic converter damage.
5-5-4 Misfire - #4 cylinder/catalytic converter damage.
5-5-5 Misfire - #5 cylinder/catalytic converter damage.
Originally Posted by
PNuT
I think you can use VOL-FCR on some of the associated components but not the engine ecu.... so you should be able to pull codes from the abs srs powerseats but not the motronic 4.3 ecu system....
although I have not tried this!
