Results 1 to 8 of 8
    538 Nm on the old car. Now
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    TDI/2.5D Problem
    OK the '97 V70 TDI is having occasional starting issues.
    Most times you crank it for 5 seconds and it fires up.
    A couple of time recently it has taked a good 30 seconds of cranking and throttle pumping to get it to fire. When it does fire there is no excessive smoke or the like and it runs fine.
    It is almost like fuel starvation on the start-up.
    It has had new glow plugs and has been timed up.
    Anyone any ideas on what it might be?
    Yes I will be behind you but
    thats for the benefit of your
    health.
    martin_r_smith's Avatar
    May 2013
    wiltshire
    585
    It may be as simple as air getting in via worn leak off pipes, really easy to change and cheap. Thats what I would start with but I have a feeling it might injection related, you'll need to plug it in to vol-fcr to confirm, or whatever is used for msa 15.8, vida??
    Look at the injection quantity when the car is up to full operating temperature, ~88 deg, and report back with that number.
    854 T5 - The new project.
    850 tdi - sorely missed.
  3. The Following User Says Thank You to martin_r_smith For This Useful Post:
    Blackdog (Thursday 5th November 2015)
  4. #3
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    Quote Originally Posted by martin_r_smith View Post
    Thanks Martin.
    If it was injector related I would have expected there to be masses of smoke on start-up from the unburnt fuel left from the cranking but there is nothing.
    Any chance of a picture of the pipes you are talking about?
    My thought was maybe the fuel filter?
  5. #4
    Jul 2008
    Red Lodge
    11
    Timing might need adjusted! We bought one off ebay that someone had fitted a manual glow plug system to solve exactly the issue you describe.... i adjusted the timing and removed all the additional parts as they were not needed! I find the eml only comes on when the timing is wrong in one direction and not the other unless it is massivly wrong but cant remember which way it is....
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=2552&dateline=1218822  313
    She may not be perfect but i love her anyway....
  6. The Following User Says Thank You to PNuT For This Useful Post:
  7. #5
    health.
    May 2013
    wiltshire
    585
    You can try fuel filter. Pipes are under the plastic cover linking the injectors together.
    With an injection quantity fault it won't be injecting enough fuel so no smoke is produced. Another symptom is the occasional catch but not full starting whilst cranking.
    Also as pnut says check the timing, I know you said it's been done but still worth checking.
  8. The Following User Says Thank You to martin_r_smith For This Useful Post:
  9. #6
    Junior Member
    May 2015
    2
    hi blackdog ive just had lots of simarler probs we were chasing various things in the end it was the starter sounds odd but have you tried jump leads straight away for a lasy starter i put a new battery in no difference new starter bingo hope this helps
  10. The Following User Says Thank You to disco For This Useful Post:
  11. #7
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    Before I rip the cover off and start delving inside are these OEM parts or just standard fuel line?
  12. #8
    health.
    May 2013
    wiltshire
    585
    Just standard fuel line, cut to size and fit yourself 10 min job
  13. The Following User Says Thank You to martin_r_smith For This Useful Post:
    Blackdog (Friday 6th November 2015)
