Results 1 to 17 of 17
    Hoping for a miracle
    Tee5alive's Avatar
    Jun 2015
    Farnborough
    312
    Coming on and off boost?
    put over 3000 miles on the car since the rebuild (new turbo, alternator etc) and initially this problem was small. But gradually this is getting more pronounced. Even trying TOP GRADE 'super' petrol its happening.
    Under hard acceleration the car boosts hard then backs off, then boost/back off etc ??? I have replaced the ETM body and this was initially suspect to no avail. It is getting VERY pronounced and boost is kicking in with a vengeance at times almost putting me through the drivers seat, wheels spinning etc (even at motorway speeds) - THEN drops to nothing?
    I am getting an intermittent ENGINE SYSTEM SERVICE due and now and then BRAKE ASSIST SYSTEM SERVICE. Which knocks out CRUISE control.
    Is this possibly simply an air leak somewhere as now and then the turbo sounds a little LOUD in the car. The car otherwise is fine, just a bit embarrassing when peak acceleration is called for!
    ideas please??
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=11614&dateline=143983  7674
    2004 - V70 D5 -'Black Bess' - The new addition
    2002 - C70 T5 'Ragetty Anne' - awaiting rebuild long term storage
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Tcv?
    Factory White 855R : 2.5 Bottom End : Ported & Flowed Cylinder Head : TD04 19T Turbo
    VXR Injectors : ME7 Manifold : TWR Throttle Body : Blackbeast IC : AEM Progressive WI : Ferrita 3" Downpipe
    Milltek Cat-Back : BC BR Coilovers : IPD ARB : AP Racing Brakes : M56 & Gripper LSD
  3. The Following User Says Thank You to S70T5Chris For This Useful Post:
    Tee5alive (Monday 2nd November 2015)
  4. #3
    Mar 2015
    Welwyn Garden City
    10
    I had this same problem and only got to the bottom of it last week, turned out to be the map sensor
    With that replaced it boosts the same all the time, everytime
    However, if you wanna try the tcv first, I have a spare here that I bought while chasing the fault that you are welcome to try (-:
  5. The Following User Says Thank You to Soulboy For This Useful Post:
  6. #4
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    Map, Maf or tcv/bcs.
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
  7. The Following 2 Users Say Thank You to Biff For This Useful Post:
    Mart5in (Tuesday 3rd November 2015),Tee5alive (Monday 2nd November 2015)
  8. #5
    Tee5alive's Avatar
    Jun 2015
    Farnborough
    312
    Quote Originally Posted by Soulboy View Post
    thanks Soulboy, on my next pitstop when I can do some work on her I'll give that a try - ill be in touch!
  9. #6
    Mar 2015
    Welwyn Garden City
    10
    No worries mate,pm me your address and I'll send it to you!
  10. #7
    Now in an Audi...to allow more
    time for my 850s lol
    Shinsplintz 101's Avatar
    Nov 2013
    Baldock, Hertfordshire
    356
    I don't want to muddy the water..... BUT... my old mans old late P1 T5 had a similar problem & it was the ABS module. Threw up weird engine warning lights, codes & intermittent boosting issues [probably due to the ECU ££££ting itself with the codes]. Don't know if the P2's suffer with the same dodgy ABS modules, but thought I'd throw it out there...good luck
  11. The Following User Says Thank You to Shinsplintz 101 For This Useful Post:
    Tee5alive (Tuesday 3rd November 2015)
  12. #8
    looking to get MTE Map
    expolicev70t5's Avatar
    Jul 2012
    Market Weighton
    251
    Got same issue on mine, then I get an over boost code and boost cut. I've got it down to be TCV that's faulty.
    Ex Police V70 T5 SE now scrapped.
    Daily driver V60 D3 R-design
    2004 C70 2.4T GT, modifications front strut brace, 19" Peg reps with white lettered tires.
  13. The Following User Says Thank You to expolicev70t5 For This Useful Post:
  14. #9
    Tee5alive's Avatar
    Jun 2015
    Farnborough
    312
    Quote Originally Posted by Shinsplintz 101 View Post
    INTERESTING as I start off with no codes then an ENGINE SERVICE on the DIM and then BRAKE ASSIST advisory - hmmmm thats interesting. Thank you all
  15. #10
    A very bad whale
    Aug 2013
    1,261
    Could be cracked abs rings, they open up when you boot it , the abs sensors then see the crack and cut your power cos they assume you are skidding, mine used to do it on roundabouts new rings cured it. The abs fault was dumping all the boost .
  16. The Following User Says Thank You to Orca2 For This Useful Post:
    Tee5alive (Sunday 8th November 2015)
  17. #11
    Member
    Mart5in's Avatar
    Sep 2015
    Great Scotland
    14
    Quote Originally Posted by Tee5alive View Post
    The brakes don't feel heavy at any point do they? Might be worth checking the pipe that goes from the manifold to the brake servo. It's got a little one-way valve on it.
    As far as I know (what my local Volvo dealer told me) the P2 don't suffer from the same ABS module faults as the P1 did. all the P2's normally fail on the front sensors and rings. Rarely the rear sensors.
    When you changed the ETM, did you fit one from another Volvo and have it coded? Or did you have it repaired with the contactless tps?
  18. #12
    Tee5alive's Avatar
    Jun 2015
    Farnborough
    312
    Quote Originally Posted by Mart5in View Post
    NO Martin just bought a used ETM fitted it , disconnected battery to reset and that was it, BUT still hunting a little on idle
    ORCA - THAT is interesting about the rings will check it thanks all
  19. #13
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Next time you're down south give me a shout & I can stick my code reader on it .
  20. #14
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Another dead thread with no result and no response.
  21. #15
    Member
    Mart5in's Avatar
    Sep 2015
    Great Scotland
    14
    Well, I know I'm not op but my situation was VERY similar and a new MAF combined with the ETM repair fixed it
    all I've got left is a misfire from cold under load. can't set off without letting the engine run for a few mins.
  22. #16
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Have you changed your plugs? Fit Genuine.
  23. #17
    Member
    Mart5in's Avatar
    Sep 2015
    Great Scotland
    14
    Yeah, I did change the plugs. Not Volvo, I used ngk but theyre the same heat rating if I remember correctly. I can't remember if the problem was there before I changed the plugs. I'll try the old genuine plugs back in sometime this week.
