So after my V70 destroyed its engine in spectacular fashion. I sourced a second hand engine which has been fitted.
All the ignition/electrics seem to be working but the engine will not turn over or start.
All wiring has been double checked, all fuses.
Any diagnostics don't seem to be able to communicate with the ECU.
I just wonder if the immobiliser is causing an issue. They actually used the original wiring loom from the old engine to wire in the new engine.
Would the car know if there was a different engine?
Been waiting around 5/6 weeks for the garage to fix it. Loosing the will with it now.
