Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
Thread: Fires then dies
  1. #41
    Jul 2008
    Red Lodge
    11
    Quote Originally Posted by oblark View Post
    The hacked M4.4 software from VS will only allow the fault codes to accessed when the engine is running, its something to do with the baud rate.
    Will try this today
    The battery is only a few months old.
    Will try this today aswell.
    I've been thinking about why it won't start,
    When it fires it revs to 1500 rpm then dies, if the throttle is depressed when the engine fires it make no difference.
    To me it's got fuel and a spark as it firing,
    But it won't run - to make it run the ecu needs to know the following,
    Amount of air being drawn in.
    Position of throttle butterfly.
    Position of the crank & cam shafts.
    As its firing you would think all of the above are working, I've changed the MAF for a working one. So today I'm going to start by trying Claymores & PNut ideas if they don't work I'm then going to changing over sensors to hopefully find the fault.
    A couple of other things I would check, or you may have checked already.... do you still have fuel pressure after it has stalled? or could it be the fuel pump is priming & then cutting out when the engine fires & dies?
    are the injectors continuing to pulse as it dies?
    do you have a spark still as it dies?
    what do the plugs look like?
    obviously some of that isn't easy to ascertain if you are working alone!
    I suspect if it had crank/cam sensor issues it would not know when to fire in the first place!
    I guess it may be worth checking the wiring to those sensors as they probably share the same plastic sheilding of the alternator wiring..... maybe you are knocking one of those sensors out when it starts?
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=2552&dateline=1218822  313
    She may not be perfect but i love her anyway....
  2. #42
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    And todays update.
    Removed alarm relay and linked out 50E & 50F - no change
    Removed alternator drive belt - no change
    So the first sensor and the easyist to be changed was the cam sensor - no change
    As the crank sensor is pain to get at I decided to have a look at the throttle switch.
    Interesting ..........
    On start up & idle the ecu needs to see 0.5V at CT (closed throttle) and I had 0.0V
    At WOT the ecu needs to see 4.8V I had 0.0V
    So it looked like the throttle switch is fubar'd I fitted one from a standard throttle body.
    And guess what...... the £$%&er started
    So the fault was a throttle switch which had gone open circuit.
    Refitted the orginal cam sensor, MAF sensor and it started again.
    Went for a drive and all was OK
    James the alternator looks to be fine, it's kicking out a good 13.8 - 14.0 volts.
  3. The Following 7 Users Say Thank You to oblark For This Useful Post:
    claymore (Monday 12th October 2015),Jamest5r (Monday 12th October 2015),jamesy12345 (Monday 12th October 2015),JT (Monday 12th October 2015),LeeT5 (Wednesday 14th October 2015),martybelfastt5 (Tuesday 13th October 2015),MoleT-5R (Monday 12th October 2015)
  4. #43
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    And todays update.
    glad you got it sorted Rob, not something that I would normally suspect, but one to bear in mind as these vehicles age further and are more likely to start chucking up these faults more often
  5. #44
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by MoleT-5R View Post
    If it didn't start it was going to get a Basil.
  6. The Following 7 Users Say Thank You to oblark For This Useful Post:
    claymore (Monday 12th October 2015),Doingitsideways (Monday 12th October 2015),Jamest5r (Monday 12th October 2015),LeeT5 (Wednesday 14th October 2015),MoleT-5R (Monday 12th October 2015),t5 pete (Monday 12th October 2015),The Flying Moose (Wednesday 14th October 2015)
  7. #45
    Jul 2008
    Red Lodge
    11
    glad its fixed!
    Wonder what caused it? or just a bizarre coincidence?
  8. #46
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Happy days
  9. #47
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    Nice one
    Bit odd that it was fine before the alternator change. As PNuT says, wonder why it suddenly went fubar? Autopsy?
  10. #48
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by Dangerous Dave View Post
    Nice one
    I had a fuel pump and a MAF fail just like that, one minute working then not.
    When the fuel pump failed a few years ago I parked it up went to start after being left for 5 mins nothing.
  11. The Following User Says Thank You to oblark For This Useful Post:
    Dangerous Dave (Monday 12th October 2015)
  12. #49
    New Identity
    Dec 2006
    West Midlands
    2,491
    Bloody cars LOL. Oh well fingers crossed it will be a lot less trouble for you now
  13. #50
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    feel your pain, had this happen on the way to work a five in the morning, tried everything but had to abandon the car and returned 14 hrs later to find I could not get her to go and she was transported home for the second time in 8 years, not bad really that she failed to get me home twice in 8 years
    lol....you'd make a great Basil
  14. #51
    All the ladies love it
    sideways!
    Doingitsideways's Avatar
    Nov 2012
    Manchester
    2,186
    Good to hear it's running again.
    Don't you just love random, complete failures?!
    Oh Dave, I love the new avatar gif!
  15. The Following User Says Thank You to Doingitsideways For This Useful Post:
    Dangerous Dave (Tuesday 13th October 2015)
  16. #52
    New Identity
    Dec 2006
    West Midlands
    2,491
    Quote Originally Posted by Doingitsideways View Post
    Cheers bud, was one I made ages ago. Was going to do another more elaborate one but never got round to it. I will eventually The sounds of each action went really well with it too.
  17. The Following User Says Thank You to Dangerous Dave For This Useful Post:
    Doingitsideways (Wednesday 14th October 2015)
  18. #53
    sideways!
    Nov 2012
    Manchester
    2,186
    I think sound effects made by the mouth like the police academy bloke, but bad, would be ace!
  19. The Following 2 Users Say Thank You to Doingitsideways For This Useful Post:
    Dangerous Dave (Thursday 15th October 2015),jamesy12345 (Wednesday 14th October 2015)
  20. #54
    Jul 2008
    Red Lodge
    11
    I was interested in the symptoms being very similar to the immobiliser for future issues so unplugged the throttle position sensor on my car & it started ran & brought on the EML so suspect it is more an issue with this particular set up....
    In general I have found very few of the sensors on these will stop the car from running
