Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41
    Sep 2015
    nottingham
    1
    At the top of sheet says maximum 215 (159)bhp @3503 rpm
    Think it's producing 215 overall and 159 at the flywheel
  2. #42
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by craig1992 View Post
    Something not right there mate - if your car is a 185 that is the approx amount of hp at the crank, with less power at the wheels. 159 sounds about right for wheel hp from 185 at the crank though
  3. #43
    538 Nm on the old car. Now
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    The higher figure would be at the flywheel. You then loose power through the transmission and end up with a "wheel horse power" figure.
  4. #44
    Sep 2015
    nottingham
    1
    Apparently it still has the police mapping in to be producing that
  5. #45
    that was torquing!
    Blackdog's Avatar
    May 2010
    Tregaron
    163
    Don't forget to tell your insurance company then......
  6. #46
    Sep 2015
    nottingham
    1
    Erm .....
  7. #47
    Bird is the word!
    dionbullock's Avatar
    Aug 2008
    north wales
    92
    Would be interesting to see what bhp my ex plod P3 D5 is?! I'd like to imagine its still 185 as it doesnt feel that quick, but isnt slow either! I'd like to think that a remap would unleash more potential, 205-215bhp at the least! For all I know, it could still have "police spec" mapping or whatever, be running 200ish bhp with no option of mapping it again to make it quicker!
  8. #48
    Iraq Lobster
    May 2013
    4,606
    Here's a calculator to get from whp to crank that I've seen used on this forum...
    http://www.mk5cortinaestate.co.uk/calculator4.php
    185 at the crank through a manual box, FWD gives 157 at wheels. Pretty close to 159 measured (if that is what it was)
  9. #49
    Sep 2015
    nottingham
    1
    Is there any way to increase the other numbers such as the 159 etc? To get more power on the road that the engine actually produces?
  10. #50
    All the ladies love it
    sideways!
    Doingitsideways's Avatar
    Nov 2012
    Manchester
    2,186
    So you want to put more power down than the engine makes?
    Erm...
    Flux capacitor, maybe?
    The power you put down on the road will ALWAYS be less than is made by the engine, due to the mechanical drag from the gearbox, etc.
    Imagine turning a load of cogs joined together in a long row.
    It will take a certain amount of effort (power) to make them all turn, this is basically mechanical drag.
    The same thing happens with the gearbox, differential, driveshafts, etc of a car. It takes some of the engine's power to move it all.
    If you want to put more power down, make your engine develop more. Simple
    If you, say, made an extra 50hp at the crank (flywheel), then you'd probably put about 45 (very rough guess) of that down, although it does get quite complicated working it out like that.
  11. #51
    Sep 2015
    nottingham
    1
    Thanks, I was just curious of getting a better percentage down if you get me. Your last paragraph sums it up. Considering it already has a police remap is there any other ways to increase power except taking the dpf off etc or anything with a massive price tag
  12. #52
    sideways!
    Nov 2012
    Manchester
    2,186
    Not really, Fella.
    Unfortunately, a remap is the first port of call.
    Any mods after that are either expensive as hell, or not really worth the bother.
    Newer diesels aren't really my thing though, so I could be wrong.
    Example on a T5:
    Remap: £300ish.
    Stainless cat back exhaust: £400ish
    Stainless downpipe: probably £200
    200 cell cat: £lots
    Bigger turbo £lots more
    Then it would all need mapping again to suit.
    Custom mapping is expensive, off the shelf maps are configured for everything else being standard.
  13. #53
    Iraq Lobster
    May 2013
    4,606
    As Steve says the only way to increase the wheel hp is to increase the crank hp first! Unless you change the transmission set up for a more efficient one!! For example auto to manual swap. If you have a go with that calculator above, from crank to wheel, manual boxes waste about 15% & autos about 20% of the available power
    If my car were making stock power at the wheels & there was no evidence (paperwork) for a map then I would assume it hasn't been mapped yet. If the dyno operator is telling you your car has 215 crank hp and 159 at the wheels then personally I think he is telling porkies. That is a 26% loss.
    No worries though that means there is a bit of scope for fiddling, meaning that you can enjoy the car even more
  14. #54
    Sep 2015
    nottingham
    1
    So what's the best way to find out what the actual hp is? Retest on different dyno?
  15. #55
    Iraq Lobster
    May 2013
    4,606
    up to you mate but that costs money. If you are sure it has been mapped & want to spend the cash then go for it. Personally I would try not to get hung up on numbers & just worry about whether I enjoyed the drive (easy to say I know)
  16. #56
    sideways!
    Nov 2012
    Manchester
    2,186
    Aye, the best way to avoid pub bragging rights is to stay out of the pub!
    Personally, I don't know for sure what any of mine are kicking out.
    I know ballpark figures from my bum cheek dyno, and I enjoy driving them.
    That's good enough for me
  17. #57
    Sep 2015
    nottingham
    1
    Yes I can safely say I love driving it. I just need to get fuel up a bit so I've stopped booting it at every green light.... unless there's a chav in an a3 or golf thinking they own the road, otherwise it's 6th everywhere at steady speed seen a rise from 31 to 38 due to being that little more typical volvo driver haha. Still can't get over the looks when I'm in traffic or get out in carpark. 23 going on 73 haha
  18. The Following User Says Thank You to craig1992 For This Useful Post:
    jamesy12345 (Thursday 22nd October 2015)
