Results 1 to 18 of 18
Thread: Misfire...
    "Just cos the got the
    power, don't mean you got the
    right"
    silverswedemachine's Avatar
    Oct 2009
    M1 Junc. 30
    15
    Misfire...
    The old girl has got the monk on and developed a misfire/shudder over night. Ive searched through misfire threads and everybody seems to have high RPM problems or WOT problems... Firstly most of the ignition is new or very good condition, only old parts are the leads n coil...
    The problem is a very noticeable shudder/misfire under half plus throttle openings starting at around 2.5k'ish and only upto 4k revs, (I say shudder hoping its not the autobox), its does this till 4k then smoothes out and gets on with business as normal. It drives fine on normal driving and lightish acceleration, kick down is a problem, it does it in more than 1 gear as well... I have very little experience on autoboxes, even less when it comes to problems with them but don't think it would create that kind of feeling... Will check oil level though as a precaution...
    Will check the obvious, comments always welcome...
    Mark
    All the ladies love it
    sideways!
    Doingitsideways's Avatar
    Nov 2012
    Manchester
    2,186
    My best guess would be a vacuum leak somewhere, hence runnng better at higher revs when it comes on boost.
    Start it up and let it idle, then spray around all the hoses and inlet manifold with carb cleaner, if it runs worse, you've found a leak.
    Wouldn't do you any harm to change the leads and coil though.
    PFV are doing a good deal on Bougicord leads (OE) at the min, just got myself a set.
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by Doingitsideways View Post
    It'll actually run better if there's a leak, as carb cleaner's highly flammable.
    sideways!
    Nov 2012
    Manchester
    2,186
    Yeah, maybe in small doses I suppose, like with a small vac leak.
    In high doses, like spraying it straight up your intake, it'll run really rough and try to stall.
    So, if engine note changes, you have a leak!
  5. The Following User Says Thank You to Doingitsideways For This Useful Post:
    stribo (Saturday 3rd October 2015)
  6. #5
    Now in an Audi...to allow more
    time for my 850s lol
    Shinsplintz 101's Avatar
    Nov 2013
    Baldock, Hertfordshire
    356
    As above, I'd be changing the leads & coil so that you can be sure you've got good spark throughout the rpm range.
    If that doesn't cure it then start searching for vac leaks.
    Good luck, Morgan
  7. #6
    right"
    Oct 2009
    M1 Junc. 30
    15
    cheers people, I will inspect all vac hoses tomorrow... Will also check out the deal on leads as well...
    Mark
  8. #7
    right"
    Oct 2009
    M1 Junc. 30
    15
    Hi all, just a quick update..
    Fired her up tonight from cold after standing since Friday night and its starts fine, idles normal but blips of the throttle has it missing plenty, definitely a ignition issue, dead plug maybe... Will have the plugs out Tuesday evening for inspection...
    Comments welcome
    Mark
  9. #8
    Nov 2013
    356
    My money is still on a dodgy lead or coil, especially as you mentioned the rest of the ignition system.had been renewed - I assume including new plugs?
    Old ht leads can arc & a dodgy could won't give you the same crank , both likely sources of a miss fire.
  10. #9
    right"
    Oct 2009
    M1 Junc. 30
    15
    ^ Yeah the plugs are only a 1000 mile old, gen' Volvo ones. Think I have another set of HT's lying around somewhere, ill swap um over then get a new set when im sure the old set are shot...
    Will inspect the ignition system Tuesday...
    Mark
  11. #10
    right"
    Oct 2009
    M1 Junc. 30
    15
    Had the car running for 5 minutes tonight before stripping it down for inspection, purely so im not working on a cold engine, any way whipped the plugs out and checked the dizzy and rotor. Dizzy and rotor are as good as can be, all plugs look to be running the same colour but... No.1 was wet through... Less than a 1000 mile on these, and one is goosed already...
    Cant find my spare set of HT leads so for the time being put the knacked plug back in a different cylinder to see if the problem follows it, have no new parts as yet so its been put back together to see what happens...
    Comments welcome
    Mark
  12. #11
    right"
    Oct 2009
    M1 Junc. 30
    15
    Forgot to add, did a compression check with 5 minute run warmish engine. 150 psi across all...
    Mark
  13. #12
    sideways!
    Nov 2012
    Manchester
    2,186
    If No.1 HT lead is shagged, no spark on that cylinder would give you a wet plug as it's not firing properly
  14. #13
    right"
    Oct 2009
    M1 Junc. 30
    15
    Hi all, quick update...
    Car is still mis-behaving, although sometimes it does seem to run fine and rev cleanly on blipping. I have put new plugs and tried another coil. Next purchase will be a set of HT leads. After that.....?
    Comments welcome
    Mark
  15. #14
    Member
    bunka T5's Avatar
    Jan 2015
    20
    Ive been having this issue on my 96 t5 auto , used to be really bad till I changed the leads, rotor cap and arm, but still apparent .. Then I started using that Lucas injector cleaner (100ml every half tank) and the hesitant acceleration has declined a LOT.. rarely I get a bit of hesitation on kickdown, then it backfires and takes off.. I think thats now down to old plugs (probably ancient .. )
  16. #15
    right"
    Oct 2009
    M1 Junc. 30
    15
    Hi people, sorry forgot to update this...
    I bought a set of new HT leads for it and all seems well...
    Now the engine is fine, it needs more power, but the inconsistent boost levels need sorting first, weak actuator I think...
    cheers
    Mark
  17. The Following User Says Thank You to silverswedemachine For This Useful Post:
    Doingitsideways (Tuesday 27th October 2015)
  18. #16
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Inconsistent boost is usually Maf, New bosch/volvo unit id have thought would sort it out.
  19. #17
    sideways!
    Nov 2012
    Manchester
    2,186
    Quote Originally Posted by merc85 View Post
    Or BCV.
  20. #18
    right"
    Oct 2009
    M1 Junc. 30
    15
    its inconsistent with levels at different times, its steady as a rock when pulling, its just next time you floor it might be less boost, but still stable, time after more boost. The boost also seems to creep up with high revs over 4k, wastegate is adjusted up a lot though so might not clearing more gas, hence the weak actuator...
