Results 1 to 16 of 16
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    850 TPS question.
    Question for the electronic gurus, I have a different throttle body I want to use on the car, the volvo 850 tps fits and bolts up perfectly, but it's reading the opposite way around, in other words when the Volvo butterfly is shut, my new throttle body is wide open. how can I swap the signal to the ecu, would it be as simple as reversing a couple of wires?
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by claymore View Post
    try measuring it with a multimeter to see what you get normally and then try different combinations to see if you can get the reverse of the previous measurements
  3. The Following User Says Thank You to MoleT-5R For This Useful Post:
    t5 pete (Wednesday 23rd September 2015)
  4. #3
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by MoleT-5R View Post
    Already tried that mate, that's how I know it reads opposite.
    PIC][/SIGPIC]
  5. #4
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    is this for the t-10 or the T-5R ????
  6. #5
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    If when the volvo throttle is shut you have a resistancce of 1.03 ohms and at fully open 1.9 ohms
    And the other one is the other way around swapping the wires over will do nothing.
    The throttle switch will need to be removed and refitted 180 degrees to get the open and closed resistance the same as the volvo TB ( I think )
  7. #6
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by oblark View Post
    Can't see how the tps can be rotated by 180% as there is a flat on the shaft so it can only go one way, so the only way I can see to use this TB is somehow modify the signal from the tps.
    PIC][/SIGPIC]
  8. #7
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    This is for the T-10's new intake manifold.
    PIC][/SIGPIC]
  9. #8
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    could the values be adapted in TT or have you bined off turbotuner
    or could the shaft be removed completely from the tb and rotated 180 degs and then re-assembled so the flat is the other way around, think I did something similar to my 3" tb
  10. #9
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    The butterfly rotates clockwise on the Volvo TB and anticlockwise on the other one.
    PIC][/SIGPIC]
  11. #10
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    I think this was why my butterfly is fitted with the shaft the wrong way around (screw ends showing not the heads as normal) I did have to turn the butterfly around else it won't shut if I recall
  12. #11
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    studying the old pic's further, maybe a hybrid tb made from different parts from different std tb's till the desired result is achieved, as you can see the standard and 3" tb's have different tps mounting plate and different linkage arms, could the desired result be achieved by mixing the parts from the 2 tb's
  13. #12
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I have had it confirmed that swapping the two outer wires over will sort it, apparently a common mod on the Lancias, cheers Dell, and when are you going to start posting on here, we all want to see your 850 project
    PIC][/SIGPIC]
  14. #13
    A very bad whale
    Aug 2013
    1,261
    You might be able to remove the shaft and motor from the throttle body and put it in from the other side , this would make the butterfly work the same as your Volvo one . IE when it was turning to open it would actually close the flap.
    Might not be possible to do . Just a thought .
  15. #14
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    that is what it seemed to say on all the threads I found, never had time to reply cos was putting the bairn in his bed!!
    Below someone made a circuit to invert the signal, then someone pointed out he could just swap the wires as you say
    http://forum.205gtidrivers.com/index...owtopic=110033
  16. The Following User Says Thank You to jamesy12345 For This Useful Post:
    claymore (Wednesday 23rd September 2015)
  17. #15
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    sorted then and easier than stripping the tb and rebuilding it
    yes it would be nice to see a build thread on Dell's 850
  18. #16
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Looks like the T-10 will be sporting a nice big Fiat Coupe Turbo TB then
    PIC][/SIGPIC]
