Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Appreciative
    kmb's Avatar
    Oct 2014
    Suffolk & Rhone Alpes
    927
    Clutch pedal sinking to floor - technical people?
    Wondering if somebody here could help me. My poor 850 T5 did 500 miles this weekend... and was faultless until I passed the keys to my aging father
    Here's the scenario - My father was driving my Volvo 850 yesterday and told me that after 40 motorway miles he pulled up to a roundabout and when he put the clutch pedal down it stayed on the floor and he could not engage any gear.
    It was pushed to a verge where he called the AA, during this time he tried to pull the lever up and it came back to the normal position, the AA contracted the job to somebody else who turned up and said something about a sticking plate somewhere maybe and take it easy he should get home OK, he then drove it home 32 miles without any serious problem. He did suggest it was maybe not as easy to select gear but wasn't certain.
    It may be a coincidence that I topped the brake fluid up the day before with fresh dot 4, it was nearly on the minimum mark and doesn't appear to be leaking and has stayed at the topped up level, as far as I can see.
    My initial thoughts are that I should replace the Clutch Slave Cylinder and have a full brake/Clutch fluid refresh. This looks a relatively inexpensive job.
    Reading previous threads, other points to check are:
    - Clutch Master Cylinder
    - Possible leaking flexi pipe under battery tray
    Has anyone had the same problem and is my approach above a good one?
    If someone can provide or tell me the best place for a clutch slave cylinder then that would also be great.
    Thanks in advance good people of the forum.
    Jul 2013
    12
    It could also be the seals in the clutch master letting by.
    Check if the carpet is wet around the top of the clutch pedal where the mastet connects to the pedal.
  3. The Following User Says Thank You to dant5r For This Useful Post:
    kmb (Wednesday 15th July 2015)
  4. #3
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Thanks - Absolutely no sign of any leak around the pedal to bulkhead or in the engine bay.
    I've just bought a replacement Unipart Slave Cylinder (ref GSY126), £25 delivered new off Ebay, which seemed very reasonable.
    Will get a full brake/clutch fluid change when this is fitted and hopefully the problem won't recur!
  5. #4
    Overall VPCUK car of the year
    2015
    craigoodwood's Avatar
    Feb 2012
    lawley village, TELFORD
    2,312
    i sometimes have to stick my foot under my clutch after a casual long journey and after that the biting point is right by the floor for a couple of mins and then back to normal....
  6. The Following User Says Thank You to craigoodwood For This Useful Post:
  7. #5
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    I'll let you know if the problem is solved by a new slave cylinder
  8. #6
    Trader
    Kingsford G's Avatar
    Nov 2011
    Colchester,Essex
    1,352
    Quote Originally Posted by kmb View Post
    The slave cylinder is in the gearbox bellhousing,if its not leaking is very unlikely to be causing this,brake master cylinder seals is most likely to be the reason as said above.
  9. The Following User Says Thank You to Kingsford G For This Useful Post:
    dant5r (Wednesday 15th July 2015)
  10. #7
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Thanks Kingsford, is this something that I can replace relatively easily or should I also just change the master cylinder for a new one? I think I've seen the seal kits sold separately.
    I'm not sure if there is a leak, nothing I can obviously see, but it looked like the fluid may have dropped a bit since topping up.
    Now back in France so won't get a chance to sort out for a month... I'll arrange the MOT at the same time as it will then be within a month of expiry. Hope it passes.
  11. #8
    Trader
    Nov 2011
    Colchester,Essex
    1,352
    The clutch master you should be able to do but the concentric slave is a gearbox out job which is not something you can do Im afraid.Look for any leaks underneath where the gearbox bolted to the engine,a slight drop could be just your pads worn down a bit depends on what u call a slight drop.Sometimes it helps flushing the clutch system but not guaranteed.
  12. The Following User Says Thank You to Kingsford G For This Useful Post:
    kmb (Thursday 16th July 2015)
  13. #9
    Lashing it up with binding
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Some slave cylinders are on the outside and i believe book time is 1-2 hour. A bleed mite get some more life out of it, although worth noting it should really be pressure bled.
  14. The Following User Says Thank You to Saaamon For This Useful Post:
  15. #10
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    The slave cylinder on the 850 looks like this, external:
    The garage quoted 1.5h to change and as mentioned it seems to be external on the gearbox housing,as shown below:
    I'll try to find out how much changing the master cylinder seals will add to the labour.
  16. #11
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    I haven't got the car to hand for the next month to see if the clutch slave cylinder is concentric or external... as I've bought an external one (didn't realise the 850 could be concentric), I'm hoping it's that external!
    It's a Feb 96 855 (OBDII), does this help define if it's concentric or external? Anyone know?
  17. #12
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    It will be external
  18. The Following User Says Thank You to Jamest5r For This Useful Post:
  19. #13
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Thanks James - I have also phoned Volvo main dealers (FRF Swansea) in the meantime, with both VIN/Reg, who also confirmed it's external, good news as I've got the correct part on the way.
    For added interest and thread info; the Volvo original parts from FRF with their 15% discount, came out:
    - Full new master cylinder = £140.67
    - External Slave cylinder = £106.60
    Final question before I book some garage time, is it a relatively simple job to replace all seals in the existing master cylinder? The main dealer did not list the seal parts separately so I'd also need to source these, if I want to go belt and braces on this fix.
    I found lots of useful pictures of the hydraulic line under the battery tray in this thread on converting an auto to manual: http://www.volvohowto.com/how-to-con...70-v70-or-c70/
  20. #14
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    I'd stick a genuine slave cyclinder on it and have a complete fluid change, brakes and clutch. Why is it you want to replace the master cyclinder?
  21. The Following User Says Thank You to Saaamon For This Useful Post:
  22. #15
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Quote Originally Posted by Saaamon View Post
    It was only based on comments above, I have already bought the new Unipart Slave which hopefully will be good quality, the car will have a full brake/fluid change when this is fitted.
    I was trying to get my head around what happened in simple terms... the foot was pressed and the clutch was not engaged when the pedal stayed on the floor, as no gear could be selected, this led me to believe that the slave cylinder had not extended (for whatever reason) to push and disengage the clutch. Lifting the pedal back up and pressing again did make the clutch work, this made me think slave cylinder had stuck.
    Brakes have worked perfectly throughout, well... as good as the standard 280mm front discs can
  23. #16
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Your brakes and clutch will feel great after a fluid change, seldom is it ever renewed.
  24. The Following User Says Thank You to Saaamon For This Useful Post:
  25. #17
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Funnily enough, it was the one remaining fluid change that hadn't been done recently, looking through the service history it's been a few years! Just booked it in for the change etc
    I'm getting ready to cross everything on the MOT part in a month's time, last time it only had advisory on rear pads/discs which have been done, but I've managed to cover a few miles recently.
  26. #18
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Always satisfing knowing the car is well serviced and up to date with fluid changes etc. Not sure if you have a project thread going but you always seem to be asking good questions, get the feeling you look after your car well. Do you run it around France when your over there?
  27. The Following User Says Thank You to Saaamon For This Useful Post:
    kmb (Friday 17th July 2015)
  28. #19
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Thanks - I don't really have a project thread, although some details of the car are here:
    http://www.vpcuk.org/forums/showthre...=855+pampering
    The car had full Volvo service history when I bought it last year, it's a particularly well looked after example for 138k miles, I've tried to go further and ensure it is in top mechanical condition. This forum had been invaluable in helping sort many of the very little technical things like vacuum pipes, BCS, improving and changing things like dodgy wiper switches, sticking boot locks etc
    Unlike your mega mileage trips across the continent; I haven't used it for the trip to my place in Lyon France as I generally use my company car 2014 A4 TDi for the haul back and forwards, the free fuel helps!
    I recently successfully used the Torque App and ELM327 to identify the leaking vacuum elbow on the left of the inlet manifold, Kingsford G was on hand with the worlds longest pliers to replace, all good stuff and a decent learning experience
  29. The Following User Says Thank You to kmb For This Useful Post:
    Saaamon (Friday 17th July 2015)
  30. #20
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Saaamon - You've inspired me to update the thread above, hopefully some of the things I find out will also help others
  31. The Following User Says Thank You to kmb For This Useful Post:
