Since doing my engine and running for a good months now, with the 15t I've noticed (very hard to miss) a massive amount of oil loss. I have checked all seals, none loosing any there, turbo return drain pipe is not loosing any, replaced vvt gasket as it was broke but still just as bad, no signs of runs anywhere which led me to believe a weak crank housing gasket to the engine possibly spraying but I really beg to differ. PCV seems good too. Your probably wondering how much is being lost. Well it's about 2-3 litres a WEEK. It doesn't smoke until gear change or overrun and it has travelled right the way under the back to fuel tank. Driveshaft is soak and so is the rack. I'm now thinking turbo oil seals but it's not burning oil from the exhaust just underneath. And whatever it's touching that's hot engines is dry too. Also this occurs under driven load not stationary revving. Any help people? Thanks
