Hi everyone, looking for some help and advice please about an engine issue I currently have with my S60R.
The car has been shimmed and is running a MTE stage 2 map with Ferrita downpipe, 3" custom catback, Snabb turbo to maf intake and VXR injectors.
The car has a misfire on cylinder 3 at start up and it maybe losing a tiny amount of coolant?
It has been compression tested, all ok, but failed the 'sniff' test. It is going to require the removal of the head to check if it may be the head gasket or a cracked liner. The cost is prohibitive just to do the check, so I am considering options in this order:
1. Darton liners with a full rebuild.
2. A late T5 2.4 engine.
3. A replacement R engine.
4. Head removal to check.
Any advice on either the issues or options would be massively appreciated.
