Page 3 of 9 FirstFirst 12345 ... LastLast
Results 41 to 60 of 170
  1. #41
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Update time.
    Mark foammanmark came over today which was good to catch up I also tried his spare ecu to which it's didn't make any improvement but the S70r original ecu wasn't showing any fault codes but now I've tried this other one here's what it brought up
    I must admit the auto box code threw me enough to ring volvo and ask weather it was a factory manual to which it is so I'm assuming that marks spare ecu must have once come from a auto.
    So I've got a few things else to check now but still not actually pin pointing any thing directly.
  2. The Following User Says Thank You to t5 pete For This Useful Post:
    foammanmark (Saturday 23rd May 2015)
  3. #42
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by t5 pete View Post
    Update time.
    Pete the VIN code starts YV1-LS5002W2 for manuals.
  4. The Following User Says Thank You to jamesy12345 For This Useful Post:
    t5 pete (Saturday 23rd May 2015)
  5. #43
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Quote Originally Posted by jamesy12345 View Post
    Cheers j ill have a look when I get back in but volvo them self's said it was a factory manual so I'm just assuming the spare ecu that mark brought came from a auto that's why it's got that code it's weird the the original ecu wasn't logging any codes going the replace tps now for the 444 code and check evap system and fuel rail pressure valve for other code
  6. #44
    Iraq Lobster
    May 2013
    4,606
    Just a thought - if a knackered ABS ECU can cause limp mode....is the right unit fitted?
    https://www.midwest-abs.com/Troubleshooting.php
  7. #45
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    I re fitted the oiginal abs pump yesterday as it was a replacement I put on while I repaired the one all faults are gone on both pumps bar a left wheel sensor so looks like that's another fault to sort.
    I've also bee reading and they do have a accelerometer sensor fitted which can reduce performance and mpg
  8. The Following User Says Thank You to t5 pete For This Useful Post:
    jamesy12345 (Saturday 23rd May 2015)
  9. #46
    SpongeBob Foamypants
    Back in a V70 and happy!!
    foammanmark's Avatar
    Nov 2011
    Nowhere near Blackburn.....
    1,604
    Great to see you today Pete, and glad that the ecu helped by throwing up some codes that might help you. Cheers for reading my codes and for the brew as well. The car will be no doubt be a belter when you sort her.
  10. The Following User Says Thank You to foammanmark For This Useful Post:
  11. #47
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
  12. #48
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    I rememeber reading through nordicks threads and noticed he said he had fitted a new rad ive noiced the rad pack is loose so im hoping he may have forgot to connect it back up.
    I wonder if it was since he changed the rad when this problem started as also on vida it stated this failing can also bring the code 621 up fuel tank pressure sensor fault.
  13. #49
    One Clean Volvo
    500tie's Avatar
    Mar 2015
    Swindon, Wilts
    64
    What a nightmare motor fair play for sticking with it, it'll be a proper sorted R once you've finished with it mate
    Sooty...
    1997 V70 2.5 10v SE
  14. The Following User Says Thank You to 500tie For This Useful Post:
  15. #50
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Quote Originally Posted by 500tie View Post
    Thank you it will certainly scrub upto be a nice car with a lick of paint and ironing out all the faults but one thisngs for sure it cannot be quicker than my gul as theres no way the misses is having a faster car than mine lol
  16. The Following 3 Users Say Thank You to t5 pete For This Useful Post:
    foammanmark (Saturday 23rd May 2015),MoleT-5R (Sunday 24th May 2015),Shinsplintz 101 (Saturday 23rd May 2015)
  17. #51
    Nov 2011
    1,604
    Looking good on the boot spoiler side of things, and hopefully I can let you know more tomoz. Also asked about the driver's side lower dash trim...........
  18. The Following User Says Thank You to foammanmark For This Useful Post:
  19. #52
    Nov 2011
    1,604
    With that mapped ecu, it could be close!!
  20. #53
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Hummm just looked for the accelerometer where vida said it would be but nothing
  21. #54
    Now in an Audi...to allow more
    time for my 850s lol
    Shinsplintz 101's Avatar
    Nov 2013
    Baldock, Hertfordshire
    356
    We nailed down a similar problem on my dads v70 the same way. So many codes we couldn't figure out what was happening.Looked deeper on Vida for what wasn't showing up where it should be. Big fat whole where the abs module should have been. Sometimes looking for the needle you just have to take the haystack out of the picture. good luck with the search fella.
  22. #55
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Hopefully sorted and due to a blocked cat removed it from the exhaust housing today and there is certainly an improvement even with it running rough with the down pipe missing so hopefully got a spare in garage and will fit it possibly next weekend if I have a hour free.
    Also any one got any crystal head lights for sale as I need to renew the head lights any way.
  23. #56
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    just bash the inners out with a long bar, that's how my olive got de-catted when the cat collapsed and as the dp was still useable I saved a few quid
  24. #57
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    I think I've got a spare cat in other garage and I'm sure I also bought the dwarfs s70r cat when I fitted him a race cat either way the blocked one will be getting weighed in
  25. #58
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Roll on tomorrow and hopefully the running issue should be sorted also been collecting other parts for the car which I didn't have so now got
    Custom rear spoiler
    Crystal head lights
    Stainless exhaust
    5 tyres
    And a comet of wobbly
    Hopefully if all goes well tomorrow ide like to have every thing sorted bar wheels and paint next weekend.
  26. The Following 2 Users Say Thank You to t5 pete For This Useful Post:
    craigoodwood (Thursday 28th May 2015),Jamest5r (Thursday 28th May 2015)
  27. #59
    One Clean Volvo
    500tie's Avatar
    Mar 2015
    Swindon, Wilts
    64
    Be nice to get her sorted Pete hopefully the replacement cat will sort it I'm looking forward to seeing this custom spoiler though
    Sooty...
    1997 V70 2.5 10v SE
  28. #60
    martybelfastt5's Avatar
    Jul 2008
    belfast
    760
    sounds good cant belive many issues this had nearly bought it myself
    1995 854 t5r
