Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2014
    1
    Oil cooler line snapped off
    Hi, so I'm currently waiting for a recovery to collect me. The lower of side oil line into the rad has broken off spewing my oil all over the road.
    It's getting dark so I can't really see but the actual hose looks intact, seems that it's was the heavily corroded house clip that have way.
    Is this a common thing to happen before I go searching when I'm home?
    I will be driving a 1.0 mk1 Micra in the meantime
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Sorry to hear that fella, hope engine is OK..?
    May be some use:
    http://www.vpcuk.org/forums/showthre...l-cooler-lines
    Sep 2014
    1
    Thanks James, yeah she's fine it was switched off immediately when the oil light came on.
    After further inspection it seems to have just been the metal clip that had deteriorated. Need to try to source a replacement.
    The 1.0l Micra is rather slow at 48HP from my normal 280 odd BHP.
  4. The Following User Says Thank You to MaxTS For This Useful Post:
    jamesy12345 (Wednesday 22nd April 2015)
  5. #4
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Get them directly from Volvo mate, had the same thing happen on our V70R, luckily the person driving it (Shem) switched off as soon as the oil light came on, and there's been no lasting damage.
  6. The Following User Says Thank You to stribo For This Useful Post:
  7. #5
    Iraq Lobster
    May 2013
    4,606
    Sounds like I need to take a look at mine....!
  8. #6
    Jul 2013
    12
    If you switched the engine off when the oil warning light came on you could have damaged the crank bearings.
    The oil pressure switch only needs 10psi to turn the warning light off and the whiteblock runs at a max of 60 psi.
  9. #7
    Sep 2014
    1
    Thanks for the info but I'm sure it will be fine as I literally drove the car round the corner.
    Volvo are having trouble location the actual part I need. Does anyone have a part number for this? Is it just the clip I need or is it the whole pipe?
  10. #8
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by MaxTS View Post
    It should just be the clip, but personally I'd replace both of them if one has failed and replace the o ring seals on the pipes at the same time to save on any leaks in the near future as they'll only be a couple of quid at the worst from volvo. I don't really like these clips and I have had one pop off after an engine out job once, though that may be down to me not getting it fully clipped in, I now cable tie them closed to be on the safe side and I have seen some jubilee clipped closed.
    Hope your sorted soon
  11. The Following User Says Thank You to MoleT-5R For This Useful Post:
  12. #9
    Iraq Lobster
    May 2013
    4,606
    The internet says that the part number for the clips is 6842411
    http://www.vpcuk.org/forums/archive/...p/t-46156.html
    Dealer will confirm
  13. #10
    Feb 2012
    135
    You don`t say what year so this pic is to compliment the pic in the link but includes part numbers...
    Attached Images Attached Images
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  14. The Following User Says Thank You to 960kg For This Useful Post:
  15. #11
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by 960kg View Post
    it's a '98 S70R Keith, so the picture you posted is correct
  16. #12
    Sep 2014
    1
    That's the one! They managed to find it in the end.
    I will be getting the clips, both O rings and an oil filter for £24.75. They will also be delivering these straight to my work on a cash on collection, had no idea they did this great service by the sounds of it.
    I really appreciate all the help involved with this though. Let's hope the rad end is not corroded too as I have not had a chance to look at it in day light
  17. #13
    The Volvo with a 'twist'!
    AcidicDavey's Avatar
    Mar 2012
    Hereford
    284
    I think the rad ends are plastic so no worry there, just clean all the remains of the old clip from the pipe and rad connection and you'll be good to go
  18. #14
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by AcidicDavey View Post
    well there's one benefit of crappy plastic radiators...!
  19. #15
    All the ladies love it
    sideways!
    Doingitsideways's Avatar
    Nov 2012
    Manchester
    2,186
    Quote Originally Posted by jamesy12345 View Post
    Unless you're running 900bhp, at which point the plasic corrodes.
    Apparently
  20. #16
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    The rad ends are plastic, but obviously the core is metal, they can part company, as my C70 one did.
  21. #17
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by Doingitsideways View Post
    Apparently
    no idea mate I'm 10 behind you at 850 hp (only at the crank like not whp)
  22. The Following User Says Thank You to jamesy12345 For This Useful Post:
    Doingitsideways (Wednesday 22nd April 2015)
  23. #18
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Always put a jubilee clip over the clips alot stronger than tie raps and gives a good hold
  24. The Following User Says Thank You to t5 pete For This Useful Post:
  25. #19
    Sep 2014
    1
    The parts arrived today from Snow Volvo. Bit pricey but they dropped them off to my work place free of charge and they are OEM items. I feel it wouldn't be right to go non-OEM for the R.
    I like the idea of the clamp over the clip, thanks. I hope the weather holds out for the weekend.
  26. #20
    Sep 2014
    1
    Managed to fix it this morning if anyone's interested.
    Just removed what was left of the old clip and cleaned up with a write brush. Put on the new clip and slid on a worm drive clamp which seemed to hold it pretty solid.
    I did not have a drain container to do a proper oil change where the car is so I have put in some fresh oil and will be doing a proper oil change next month. the filter was only a few thousand miles old and genuine Volvo so all's good.
    I ran it for about 20 mins, holding revs ect and no leaks. Unfortunately I had to fill up the micra so the test drive will be this evening :/
Tags for this Thread
