Results 1 to 12 of 12
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    Will it need to be 'Re mapped' after me maf.
    Can some one with more technical knowledge than me, (which to be fair is every living thing above dogs!) help me understand what is needed.
    at the minute I have a standard maf and all plastic pipe work with a pipercross cone filter.
    But some very kind and wonderful people have donated these parts to me
    Will I need to have my map altered or will it compensate on its own?
    If I do who can do it?
    I've had different opinions from very knowledgable and trusted people but I don't want to go bang................AGAIN!
    It's a 3" maf housing and 3" maf/ turbo pipe, yes they are shiney that's why I like them.
    Thanks in advance.
  2. The Following User Says Thank You to Nealevo For This Useful Post:
    Jamest5r (Friday 3rd April 2015)
  3. #2
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    My opinion would be 'yes'...at the very least check AFRs when your new bits & pieces are on. The idea of this is I guess to let more air in, so the system will compensate to an event but there will be a limit, beyond which you could run lean.
    My/Yosser's S70R was mapped by Tim W/T5D5 chaps...maybe worth asking Tim who can map it
  4. The Following User Says Thank You to jamesy12345 For This Useful Post:
    Nealevo (Friday 3rd April 2015)
  5. #3
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    personally, I think it will be fine as long as you don't use an MBC on it.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  6. The Following User Says Thank You to claymore For This Useful Post:
  7. #4
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    Quote Originally Posted by claymore View Post
    Thanks, I don't have MBC as I can't be trusted with boost will my Blue injectors be ok or will they need upgrading etc etc
    As you can tell I'm lost
  8. #5
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    You will need it remapped for the larger MAF,
    At present your ecu nows how much air is being drawn into the engine, with the larger MAF MORE air will be drawn in which make the engine run LEAN.
  9. The Following User Says Thank You to oblark For This Useful Post:
  10. #6
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    You need map also neal get a far gauge it will dramatically lean the car not a wise over as some have found out all ready
  11. The Following User Says Thank You to t5 pete For This Useful Post:
  12. #7
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I ran a 3" maf for quite a while on a hlm map before I changed to turbotuner ecu, but an afr gauge is always a must imo.
    Edit: come to think of it, I was using an adjustable fuel pressure regulator so I upped the fueling a bit, so ignore my advice I'd forgot all about the fpr i was using at the time
    PIC][/SIGPIC]
  13. The Following User Says Thank You to claymore For This Useful Post:
  14. #8
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    I have an afr gauge too so I can see when it's bad
  15. #9
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Colin and ade were with me at a meet when I fitted mine and it ran lean on idle think about 17 if I remember
  16. #10
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    Is 17 not good then ????? Lol
  17. #11
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Er......no, ideally you want 14.7 on idle or thereabouts, 11's on boost /wot
  18. #12
    Jul 2008
    2,869
    I would advise you to get it checked at least, mine was custom mapped and then I replaced the standard Volvo piping from the maf to the turbo with the 3" pipe work very similar to what you've got, didn't have it checked and I bent a rod the very next day when it had previously been fine for a year and half prior to the pipe fitment....Just saying
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  19. The Following User Says Thank You to AndysR For This Useful Post:
    Nealevo (Saturday 4th April 2015)
