I have now got a stack boost gauge installed in the C70.
My boost is set to 10 psi max so stock by the look of things.
If i go WOT from say 1500 - 2000 rpm the boost will build to 12psi approx for about 1 second then drop to a perfect 10 all the way.
If i go WOT from say 2500 - 3000 rpm i will spike up to 13-14psi max again for about 1-2 seconds then drop back to 10 all the way up.
I get a feeling of the car holding back a little when the boost drops back as you would expect.
Is this normal behaviour? Or does this mean perhaps my actuator rod is too short and needs winding out a bit?
I am trying to get everything hunky dory before getting a map loaded on the car
