Results 1 to 13 of 13
    Jan 2005
    Midlands
    0
    RICA Upgrade - power in 4th
    Is it normal for there to be an obvious reduction in power in 4th compared to 1st, 2nd and third? Given how smooth the power delivery is throughout the range, I would have thought it would atleast be a gradual decrease in power rather than you change into 4th and there's an obvious and immediate decrease in power?
    Just wondering if something's amiss, or whether it's normal?
    Cheers
    Mark
    Volvo till i die
    mikey's Avatar
    Feb 2005
    bexhill-on-sea
    18
    have you got the 280bhp or the 304bhp version?
    be a sinner drive a volvo
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Mark if you change gear fast the boost drops for a second then climbs again, its always done it, i imagine thats what you mean
    <a href="<a href=http://s65.photobucket.com/albums/h225/RobertBingley/Misc/?action=view&current=Animation1.gif target=_blank>http://s65.photobucket.com/albums/h2...Animation1.gif</a>" target="_blank"><img src="<a href=http://i65.photobucket.com/albums/h225/RobertBingley/Misc/Animation1.gif target=_blank>http://i65.photobucket.com/albums/h2...Animation1.gif</a>" border="0" alt="Photobucket"></a>
    Jan 2005
    Midlands
    0
    Cheers guys
    mikey - 304bhp I believe.
    Justin - I'll go out and check that... to be honest, I didn't even look at the boost guage when doing it.
    Cheers
    Mark
  5. #5
    Jan 2005
    Midlands
    0
    Justin - right you were mate It got up to full boost after a few seconds. Don't suppose you have any ideas on the cause, or what can be done about it?
    Cheers
    Mark
  6. #6
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Nope ask Adam @ VT
  7. #7
    Jan 2005
    Midlands
    0
    No worries mate, cheers
  8. #8
    Junior Member
    Feb 2005
    Stoke-on-Trent, Staffs
    0
    Mark, I noticed no reduction in power on our little spin on the motorway.
    However, I do drive a 2.0 Vectra
  9. #9
    Aug 2004
    Braintree, Essex
    0
    I think you'll find is rev's related, i.e. when you go up into 4th the revs drop to the point that its not best to be boosting that high at that revs due to heat and load on the rods. Once the revs have risen a little more the ECU allows full boost again. The feeling of power loss is then made worse by the change in gear ratios.
    SAM ECU
    Custom Super 60 18T Turbo With Uprated 300/70 W/G
    Blitz Dual SBC Boost Controller
    Blue Injectors
    NGK Iridium Spark Plugs
    Custom 1 Box 3" Turbo-Back Exhaust
    TurboXS Type R-HFL
    K&N Style Cone Filter With Cold Feed
    87 Deg Stat
    Full Poly Bushed
    Custom 60mm Drop Suspension
    Strut Brace
    18" Shadow Chrome Pegs
    305mm Drilled Brembo's With Ferodo DS Pads
    6000k HID Kit
    Flat Areo Style Wipers
    See All The Pics Of SAM Here
  10. #10
    Jan 2005
    Midlands
    0
    Cheers Bracer, I'll take a look and see if I can find any correlation, although nookie's due for a service within a week or so ... piling on a few miles on her
    Chris - it is noticable, although it took me a little while to spot it.. I guess it's one of those things that once you know it there, it gets on your pecs a bit. Mind you, still lovely to drive.. I just don't want that little lag there
  11. #11
    Dec 2004
    54
    Mark,
    What, exactly, are the revs, and what is the boost (in bar) when you feel this 'drop' in power ?
    Please tell me that you are aware you have bought a Volvo T5 and not an inter Gallactic ground attack missile !
    You do need to spool turbo's up in the previous gear to get them to boost in the next gear. i.e. If you want full boost straight away in 4th you will need to use the full rev range in 3rd.
    As your engine is an older unit (and does not have vvt, and has hydraulic lifters) there isn't much point revving past 6000 rpm.
    Please advise revs and boost.
    Regards,
    Hamish.
  12. #12
    Dec 2004
    54
    Mark,
    Just reread your post.
    I've sussed what the drop in power is....Justin is quite right... there is a deliberate drop in boost when you load the engine up in 4th.
    This is quite deliberate in the mapping, it is there to save the con rods from bending !
    Regards,
    Hamish.
  13. #13
    Jan 2005
    Midlands
    0
    Hamish - cheers for the replies. Oh well, I can live with it as long as it's not a problem with the car
    I'll be giving you a bell over the next few days regarding a service for her.
    Cheers
    Mark
