Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Member
    Sep 2014
    0
    huge loss in power
    Another problem with the Volvo still getting the vvt coming up as a fault the car is running slow extremely feels like a 1ltr could the vvt solenoid make the car run like this?
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Depends what you are used to...they are not light cars but a '99 T5 should be quick enough, no VVT would reduce power but not by that much
    Fuel consumption OK?
    Member
    Sep 2014
    0
    Its hugly down in power bud its like the turbo isn't working atal if I put my foot down you can feel the turbo trying it might burst into life or nothing atal car sounds like its down in power to
    Mar 2010
    Bradford, West Yorkshire
    88
    invest in a boost gauge and pod dude and check your pressure. Easy way to check it and you also get a boost gauge into the bargain
    1997 V70 R
    Fully adjustable Koni's
    3" Jetex front to back
    Carbon Filter
    Black Comets
    Full tints all round
    The girls a stunner!
  5. #5
    Member
    Sep 2014
    0
    I have a boost gauge mate boost is just over 6bar
  6. #6
    Appreciative
    kmb's Avatar
    Oct 2014
    Suffolk & Rhone Alpes
    927
    I think you mean psi (14.5 psi to a bar) 6 psi is well down on the standard T5 where you should be around 10psi of boost in standard form, if you mean 0.6 bar this is also a little low but sounds not too far off the mark...
  7. #7
    Member
    Sep 2014
    0
    Sorry yes 0.6 bar
  8. #8
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    VVT only affects the power over 4-4,500 rpm, and not by that much. Although .6 bar is a bit low, it shouldn't feel gutless.
  9. #9
    Member
    Sep 2014
    0
    Must be something else which isn't throwing a code just drove it about and it was running with power again turbo quite noisey well loud air realeasing noise. When car was losing power I couldn't hear turbo noise it felt like I was driving against 300mph wind starting at 0mph in 5th gear!
  10. #10
    Yes I will be behind you but
    thats for the benefit of your
    health.
    martin_r_smith's Avatar
    May 2013
    wiltshire
    585
    Sounds like a split boost pipe to me.
    854 T5 - The new project.
    850 tdi - sorely missed.
  11. #11
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by martin_r_smith View Post
    I fully agree ^^^^
    If your getting a 'loud air releasing noise' as you put it, then you clearly have a boost leak.
    Check your hoses have not come disconnected first where the jubilee clips are.
    Second, check all your hoses and squeeze them. Your feeling for a split in the pipe.
    Thirdly, if all above ok, then your likely to have a split IC. (More common than you think) look for oil residue on the back of the IC, at the sides, This is the give away!
    Otherwise, it's your Turbo.
    Good luck!
  12. #12
    Member
    Sep 2014
    0
    Hoses are fine new samco ones fitted a couple of months ago.
    What is the ic? Intercooler? I only have the air releasing noise if car is running with power if no power I hear no air leak
  13. #13
    health.
    May 2013
    wiltshire
    585
    Even if they were new it's still possible a jubilee has come loose, personally I'd still check them all.
  14. #14
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by Volvosean View Post
    IC = Intercooler.
    Just because you've fitted new Samco hoses, as Martin says, doesn't mean they're not split. I can tell you from experience that silicone hoses are notorious for coming off especially when using those crappy wide band clamps! The clamps don't bite into the hose as a normal jubilee does and they will pop off if the clamp is not tight enough.
    What do you mean....'with power, if no power no leak'? Do you mean you only get air rushing noise when under boost ie your foot to the floor accelerating?
  15. #15
    Member
    Sep 2014
    0
    When the car is running with power is when I can hear the air escaping when I put my foot down
    When the car is running as fast as a 50cc moped I can't hear air escaping
  16. #16
    has moved over to the dark
    side
    Joolz_850R's Avatar
    Jul 2010
    Northants
    50
    I had really low power when I first got my R. Would not boost at all. Changed all pipes relating to vacuum. Turned out to be a blocked cat. Exhaust was not allowing the turbo to spool up. Have you had a misfire at any time?
    850 TI R D
  17. #17
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Of course you can't heare any air leaking when you are going slowly, you aren't boosting then, when the turbo boosts is when you will hear the air leak as the pressure is opening up a split or an incorrectly fitted pipe.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  18. The Following User Says Thank You to claymore For This Useful Post:
    LeeT5 (Tuesday 10th March 2015)
  19. #18
    Member
    Sep 2014
    0
    Quote Originally Posted by Joolz_850R View Post
    Yes when I first braught the car it had a misfire but dusapeared after new plugs
  20. #19
    Member
    Sep 2014
    0
    Quote Originally Posted by claymore View Post
    My foot is to the floor fella upto 5k revs
  21. #20
    darzmat's Avatar
    Sep 2013
    1
    I think he means sometimes the car runs well and other times its as slow as a 50cc moped. Not that he's driving slow.
    So when it is running and the turbo is spooling he is getting the air release sound.
    And when its running really bad and slow he's not getting the noise
