So i have had problems with something draining my battery. Just bought another new battery and before i go as far as a new alternator as well, i thought i would check to see if anything is draining the battery.
I found this guide which seems straight forward to follow http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Followed it as far as step 4 and this is what my multi-meter is showing....
Is this is a good reading or a bad reading? Have i set the MM correctly? I had the -ve side directly on the battery and the +ve side on the cable.
Any advice would be good
