Results 1 to 17 of 17
Thread: Oops
    miltski's Avatar
    Jul 2008
    0
    Oops
    Think I'll be ok?
    Untitled by miltski1, on Flickr
    Might need more than the water pump that seized methinks?
    So do I sell the R for peanuts now or spend loads getting a new engine?? Surely I'll never be so lucky as to have not bent loads, happened at 50mph today, loss of power car stalled and I coasted to side or road( well a406 during rush hour)
    And cried a little when I saw cranks weren't turning so took cam over off and saw the seized water pump and belt with chunk taken out boo hoo!
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Bent valves at best whip the head off and see if there is any damage to piston tops and inspect the condition of the cylinder walls
    Old Fat Git with Grey Beard
    Need to prepare to do
    Santa-ing
    Santa's Avatar
    May 2010
    Frimley
    1,497
    Aaaaarrrrrrr, that wont buff out.
    Any suggestions, information, complaints or grievances relating to this forum please feel free to contact us, talk to a mod or administrator
    Cars : 2009 VW Passat CC 140 CR & 2015 VW Golf R. Uploaded Albums. Past Statuses (Or is that Stati?). Past Posts.
    miltski's Avatar
    Jul 2008
    0
    Still waiting for recovery, no tow as awd. Only been couple hours so far!!
  5. #5
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    TBH and Pete probably knows as well, but doesn't want to make you feel worse, if the valves have come in contact with the piston heads, which they will have done, then the pistons will be damaged too. Your best bet would be to try and source another engine if you plan to keep the car. Sorry this has happened to you, but before making any rash decisions, sleep on it.
  6. #6
    miltski's Avatar
    Jul 2008
    0
    Engine has done 175k so I think easier to get another engine? Not much more in time to remove and replace all these bits as I don't have garage facilities or even a driveway to do the work on. Only bought the car few weeks ago, done pcv already and few bits cambelt/water pump were next on list for "piece of mind" now the belt and water pump is in pieces.........
  7. #7
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Oh £££££, I feel your pain.
  8. #8
    "Need More Power
    Captain"
    c70geoff's Avatar
    Jul 2012
    Pontypool, South Wales
    651
    ££££ dude not good
    feel for ya
    C70 2.4 T Saffy Pearl now dead and stripped
    850 T5 "the Turk" wagon
    V70 D5 parked up for sale
    V50 1.8s family wagon
  9. #9
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Why, did I not give the right information?
  10. The Following User Says Thank You to t5 pete For This Useful Post:
    stribo (Friday 6th March 2015)
  11. #10
    miltski's Avatar
    Jul 2008
    0
    Still at side of road as wrong vehicle sent to recover me, have had time to get cabin fever, can I not get another t5 engine and use my turbo and injectors etc? It's a pre me7 surely the R's were not that different engine-wise?
  12. #11
    Volvo Mangler
    Hound's Avatar
    Nov 2014
    Hope Mountain, North Wales
    256
    Ouch. Sorry to see that.
  13. #12
    miltski's Avatar
    Jul 2008
    0
    Still waiting recovery only four and a half hours since I broke down
  14. #13
    "Need More Power
    Captain"
    c70geoff's Avatar
    Jul 2012
    651
    bloody recovery drivers
    what area are you in?
  15. #14
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    As far as I know the t5 & R engines are the same its just the turbo, injectors and ecu sof££££e that is different
  16. #15
    Now in an Audi...to allow more
    time for my 850s lol
    Shinsplintz 101's Avatar
    Nov 2013
    Baldock, Hertfordshire
    356
    The 2.3 t5 lump is the same in t5s/Rs. As oblark says above, just swap the ancillary items from your old engine the the new & drop it in. Just make sure you get an me4.x engine, not the the later me7 lump, for a straightforward swap.
    P.s do you want me to refund the money for the polybush ? Let me know.
    Good luck & shop around for a replacement lump, plenty of duds floating about!
    All the best, Morgan
  17. #16
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by t5 pete View Post
    You only gave half the information.
  18. #17
    miltski's Avatar
    Jul 2008
    0
    Quote Originally Posted by Shinsplintz 101 View Post
    Morgan every little helps, this is just the thing forums are about thanks
    I think I will have to sell the car as it is which means someone if they have the facilities will get a bargain, but I can't keep paying insurance and road tax for something which I doubt will get fixed anytime soo. The choice is to get it trailered somewhere then wait until an engine becomes available but I simply don't have this opportunity.
    I am so upset I bought this car literally a month ago and the day she died was the first day the mpg was showing over 30!
