Ahoy.
So, my idle has been random since I got the car a month back, would be between 900 to 1.1k (ish) most days after driving..
Today however it was a bit odd, after driving to a destination and leaving the car parked for about 30-40 mins, then starting back up and let the car idle for a minute or two the idle /revs shot up to about 3k,
I let it continue for about 10 seconds to see if it would settle but no avail so I shut it down, checked under the bonnet (always my main plan of action) checked coolant, under the filler cap, dip stick, nothing smelled hot or over heating. Then tried to fire her up again and just turned over. Tried several times, nothing. Left it for about 5 mins and then tried to crank it a final time and it finally started with a slight bit of hesitation.
Continued to drive a bit more and its been completely fine, even did a few test stop / starts and again no issue. I've not let it idle for more then a minute before shutting it off yet, however. I've read someone had similar issue here - (http://www.matthewsvolvosite.com/for...hp?f=1&t=21479)
Does it seem likely?
- Volvo 850 t5 96'
Cheers
**awaiting a link to a Robert DIY video** :p
