Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 66
  1. #41
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    Quote Originally Posted by JamesT5 View Post
    PMSL! Your comments made me laugh!
    You're "welcome".
    Factory White 855R : 2.5 Bottom End : Ported & Flowed Cylinder Head : TD04 19T Turbo
    VXR Injectors : ME7 Manifold : TWR Throttle Body : Blackbeast IC : AEM Progressive WI : Ferrita 3" Downpipe
    Milltek Cat-Back : BC BR Coilovers : IPD ARB : AP Racing Brakes : M56 & Gripper LSD
  2. #42
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    The parts would be no good by the time he'd cut them off with an angle grinder.
    Another 'witty' comment from Steve..... I'm actually smiling at these everyone so keep 'em coming.
  3. #43
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by S70T5Chris View Post
    You're "welcome".
    I hope 'it' has stopped itching now. If not I'm sure this thread will shed some 'light' on the problem.....
  4. #44
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    And as always james, nobody cares
  5. #45
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    55W 5000K on dipped and main, brilliant bit of kit, lights the road up like a football stadium. I've only been flashed once plus I'm fitting the H7R anti-glare bulbs soon.
    your headlamp lenses are reflector ones I would of thought so the H7R anti glare bulbs won't work with them.
  6. The Following 2 Users Say Thank You to MIKESC70T5 For This Useful Post:
    S70T5Chris (Sunday 8th February 2015),shepbomb (Sunday 8th February 2015)
  7. #46
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by MIKESC70T5 View Post
    On the contrary, H7R bulbs are designed to be used with reflector lenses, what do you think the 'R' stands for... 'Rally'? In fact, they actually state that the H7R bulbs are not suitable for projector lenses.
  8. #47
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    Ahh okay my mistake. So that's another £41 on bulbs. How's your money saving exercise working out running two cars that are forever bleeding you dry according to your Facebook threads?
    Oh by the way, I'm keeping my responses civil, so I'd be happy if you would be so kind as to do the same
  9. #48
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    On the the one hand James, I find most of the posts you write to be irritating, completely useless and a constant attention seeking wind up.
    But then on the other hand it's 'THE' 'HUGE' '££££ING' 'OVERUSE' 'OF' '££££ING' 'INVERTED' 'COMMAS' 'FOR' 'EVERY' 'OTHER' '££££ING' 'WORD' 'THAT' 'REALLY' 'MAKES' 'MY' 'D!CK' 'ITCH' 'THE' 'MOST'. <----- Yes this was 'SHOUTING'.
    Good luck getting your stadium lights to function properly. Maybe you just ££££ed something up? That wouldn't be out of the ordinary would it?
    As you were.
    I believe the correct terminology is 'As you were...gents'!
    James, there's no need to be such a jumped up £££££ about it.
    To clarify, James you are correct that the bulb shown in your link IS meant for reflector type lenses. If the bulb did not have the 'filter' on the glass then it would only suit projector type lens. However, there is no such thing as a H7R bulb! The R may well stand for 'Reflector' on HIDS4U's website, but that is something they have made up.
    Traditionally there is only a H7 bulb. All HIDS4U have done is taken a 'H7' fitment and made a HID bulb to suit and due to it 'illegally' being fitted to a reflector type lens, they've fitted the filter to the glass, which does not make it legal.
    So Mike, you are not mistaken, just mislead by James.
  10. The Following User Says Thank You to LeeT5 For This Useful Post:
    MIKESC70T5 (Monday 9th February 2015)
  11. #49
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Oh yes, there most certainly is...... http://www.hids4u.co.uk/h7r-anti-gla...hid-bulbs.html
    Have a look at there FAQ link.
    Is HID xenon Legal?
    Unfortunately no aftermarket HID kit is strictly road legal as you are changing the lighting system (from halogen to gas discharge) in your car and for this reason the bulbs can't be E marked which is a legal requirement. You also won't have the self leveling and washer systems installed which is also a legal requirement for HID and without these installed the kit would be an MOT failure. HID kits are plug and play so they are easy to remove and replace with standard bulbs come MOT time.
  12. The Following 2 Users Say Thank You to Harvey For This Useful Post:
    MIKESC70T5 (Monday 9th February 2015),shepbomb (Monday 9th February 2015)
  13. #50
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Mike, you need to remove the picture that belongs to me from your avatar and signature picture. You do not have permission to use it and this violation has been reported to site Admin! Please do not upload pictures that belong to me without my permission.
  14. #51
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    you stuck it in the public domain, so I can see why he can re-use it on your thread.......
  15. #52
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Took you a couple of days to look that up did it?
  16. #53
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    James why don't you remove yourself from a forum that doesn't want you.
  17. The Following User Says Thank You to Ettienne For This Useful Post:
    LeeT5 (Monday 9th February 2015)
  18. #54
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by MoleT-5R View Post
    Because I own the photo and he doesn't have permission to repost it!
  19. #55
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    I found that picture on " Britains most Hated " are you sure it's you .
  20. The Following User Says Thank You to MIKESC70T5 For This Useful Post:
  21. #56
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    don't see any copyright mark on it and looking at it, you didn't take it someone else did, so if anything its there pic, did you have permission to use it in the first place....
  22. #57
    Jul 2013
    12
    One thinks that James has spat out his dummy.
  23. #58
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    No, I took that photo and own the right to it. If the signature picture isn't removed swiftly, then the issue will be reported to the social networking site on which I posted the photo with a view to taking action.
  24. #59
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Hahahahahaha, well people we all know what to do now.
  25. The Following 2 Users Say Thank You to stribo For This Useful Post:
    Ettienne (Monday 9th February 2015),LeeT5 (Monday 9th February 2015)
  26. #60
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    grow up you big baby... what you don't like your own picture... find that most amusing you want to be all over this forum why not let Mike help...you'll enjoy kicking off again and trying to be centre of attention again
  27. The Following User Says Thank You to MoleT-5R For This Useful Post:
