Hey all. so i got a small problem with the aux belt on the 850 if anyone can help me. the tentioner started to grind with bearing failure so i ordered a new belt. tentioner. and pulley thinking why not replace everything while its off. installed both items fine BUT. when it came to put the belt back on the new volvo belt was nowhere close to going on even with the tentioner locked in its lil position with the pin tool it wouldn't go. the old belt is about 2 inch maybe more longer from stretch i presume. has anyone ran into this issue before? on the old tentioner i had tonnes of slack as i have removed that belt at least 4 times without this issue arrising.
even the old belt with the new tentioner was HELLISH tight going back on even in the pinned possition n had to be pushed on to get it over the P/S pump so should i maybe try streaching the new belt in a extreme hot water bucket bath. or wait for the tentioner to loose some of its strength?
the belt number is 946557 and as states is for a manual 850 with air conditioning as mine has.
the tentioner is 1275380
and the idler is 6842620.
im wondering if i needed the belt 9186352 as it says FWD A.C but nothing more. anyone got any ideas?
