Results 1 to 18 of 18
    Junior Member
    This user has no status or
    indeed a life!
    Sep 2014
    West Sussex
    13
    Questions for T4 owners
    I am getting a 1999 V40 T4 tomorrow and when I looked at it I noticed that it has a manual boost control under the bonnet. I think it would be a good idea to fit a boost gauge so I know it is set right, have any of you fitted gauges and if you have how and where in the car have you fitted it? Have any of you fitted manual boost controls and if you have what boost do you have it set at or what should it be as standard?
    A few questions I know but I want things to be right so your answers will be welcome.
    Wiping smiles off faces!
    Dec 2013
    Portsmouth
    87
    I played about with a manual boost controller on the car, however I found out it made no difference on mine because it is ecu controlled.
    If this is the phase 1 then it might be different.
    I turned the actuator round on mine to turn the boost up to 18psi.
    As regards to the mounting of it, I found it annoying on top of my dashboard so have placed it under the stereo in that cubby hole, I know it's not a safe place but it's out of my windscreen and let's just face it, I don't need to look at it every day.
    Standard psi should be 12.
  3. The Following User Says Thank You to RichT4 For This Useful Post:
    310den (Sunday 25th January 2015)
  4. #3
    mitchyboy01's Avatar
    Jun 2011
    Deal, Kent.
    161
    I would bin the MBC and run the stock BCS. Stock should be 14psi.
    Grey 855R Manual. Totally standard.
  5. The Following User Says Thank You to mitchyboy01 For This Useful Post:
  6. #4
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    Thanks for the replies. I was just looking at those gauges on ebay. It is a phase one so perhaps a previous owner found it useful having a manual boost but I don't know what it is set at. On the test drive it felt OK, plenty of boost and no horrible noise from the turbo but it is handy to know what the standard psi should be and what you can safely go up to also. I think the standard boost sensor is still there, will know more tomorrow when I get it.
    1999 V40 T4 SE
  7. #5
    Jun 2011
    Deal, Kent.
    161
    Yes it depends where you read about boost but some figures say 12psi, 13psi and 14psi lol. Mine was 14 on the gauge. I would say get a gauge and see where you're at before you tinker with boost settings.
  8. The Following User Says Thank You to mitchyboy01 For This Useful Post:
  9. #6
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    Quote Originally Posted by mitchyboy01 View Post
    Yes that's the plan as have no idea what it is set at. Is 18psi safe for a bog standard engine or is that asking for trouble?
    1999 V40 T4 SE
  10. #7
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    ^^ what they said, might be worth doing a search on how to check your actuator as well. My MBC made things worse on my T4 cos the actuator was screwed.
    Current Garage:
    *Data Sept 2013
  11. The Following User Says Thank You to JUDGENINJA For This Useful Post:
  12. #8
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    I had a t4 that was running 18-19psi, but that had been remapped which, if done properly, should be more reliable.
  13. The Following User Says Thank You to LiamT4 For This Useful Post:
  14. #9
    Dec 2013
    Portsmouth
    87
    Mine isn't mapped, bloody quick but very thirsty
  15. The Following User Says Thank You to RichT4 For This Useful Post:
  16. #10
    zoidberg's Avatar
    Jan 2012
    Batley, W.Yorks
    6
    Stuff all that cobblers ( even if correct, lol )
    Just plant your foot down and see how you like it !
    My recently bought T4 of '99 vintage with another scrapyard turbo fitted starts to light the wheels up at 3000 revs and 'hops about a bit' from there on in ! No idea what it is running and don't really care as most of my driving in it is around town/city and still return about 30 mpg ....................less when I clog it up yhe motorway stretch fom Leeds or Bradford.
    In other words JUST ENJOY THE DAMN THING, no one can say how the feel in YOUR car as it is a personal decision.
  17. The Following User Says Thank You to zoidberg For This Useful Post:
    310den (Monday 26th January 2015)
  18. #11
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    Quote Originally Posted by zoidberg View Post
    I intend to enjoy it, I just want it to run as well as possible with as much boost as safely possible but not knowing what it is set at concerns me a little so a boost gauge is top of the list to get.
    1999 V40 T4 SE
  19. #12
    'Ow do
    Haizum74's Avatar
    Mar 2010
    In me 'ouse
    919
    18psi should be ok just don't floor it until the revs get up.
  20. The Following User Says Thank You to Haizum74 For This Useful Post:
    310den (Wednesday 28th January 2015)
  21. #13
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    Quote Originally Posted by Haizum74 View Post
    Thanks for that, may go a little less as don't want to hurt the old girl although there is pleny of life in her. May try around 16psi if it is OK with this MBC on, if not I will put it back as standard.... for now.
    1999 V40 T4 SE
  22. #14
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    I think for now I would like to put it back as standard until I get to know this car, give it a service etc...
    The problem is i don't know which hose goes where on the original boost controller. One pipe has a Yellow band on, the other a Blue band but what goes where? See photos.
Size:  220.3 KBName:  2.JPG
    1999 V40 T4 SE
  23. #15
    Jun 2011
    Deal, Kent.
    161
    Quote Originally Posted by 310den View Post
    Here you go
    http://www.volvoforums.org.uk/showthread.php?t=135924
  24. The Following User Says Thank You to mitchyboy01 For This Useful Post:
  25. #16
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    Thanks for that, it was pointed out to me over there on a similar thread and that the diagram should be under my bonnet but if it is I missed it. At least this confirms it. Cheers.
    1999 V40 T4 SE
  26. The Following User Says Thank You to 310den For This Useful Post:
    mitchyboy01 (Wednesday 28th January 2015)
  27. #17
    UK League Champion SQ Advance
    4k Euro EMMA
    Apr 2006
    64
    My T4 when it runs is on 18psi
  28. #18
    Junior Member
    indeed a life!
    Sep 2014
    West Sussex
    13
    Quote Originally Posted by Slomo View Post
    Great, thanks for that...lol at when it runs.
    1999 V40 T4 SE
