NO. The set you've bought are Bi-xenon bulbs. When you pull your high beam switch the relay will energize a magnet in the base of the bulb and pull the bulb backwards. This will then filter the light through the metal sleeve onto a different part of the reflector.
You only need the one kit.
Correct, it does. As above mate for explanation.
I have these on my work van and they are super bright!
Saaamon (Monday 5th January 2015)
Must say LeeT5 you certainly know your stuff regarding HIDs.
LeeT5 (Monday 5th January 2015)
