just out of intrest
just out of intrest
I think there are a few yanks running them on red blocks.
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
Twin scroll won't work on a 5 cylinder really.
PIC][/SIGPIC]
P1 V70 2.5T Scorpion Exhaust, 3" downpipe 100cel cat, BSR induction, KKK24, GWE 3" Maf to turbo pipe,japanifold , 2010 V50 T5 Alloys Projector Headlamps with 5k Hid kit Quickshift kit, strut brace, Koni Yellow Sport,IPD BCS AET motorsport remap
Previous: 2004 XC90 T6, 240GLT Estate, 343DL
Toys: Capri 3.7 Twin turbo, Kawasaki ZX10R 2006,
seems alot of audis putting them on like
PIC][/SIGPIC]
Bulkhead clearance will be a big issue unless you get a custom manifold and you will need an external wastegate.
I think the HX40 will be a T4 flange, so will need an adaptor to mate it to any Volvo manifold. Be prepared for serious lag with such a huge turbine wheel!
Saying that... I do think Holsets are fantastic turbos. Great spool (for their size), cheap and reliable. The turbine housing size will need to be considered as some of the Holset housings are HUGE!!
An HX or HY35 may be a better option for spool times, driveability and T3 flange (same as Volvo). These are still capable of around 500bhp although the HY maybe a bit less than the HX. If using the internal gated Holsets you will need to bore out the wastegate flapper hole to prevent boost creep which is a common problem when running them on petrol cars. Most Holset actuators are set to silly high boost so some people modify the bracket and fit their own actuators.
The main reason Holsets fail on custom installs is the oil return. They need a big return pipe or you will kill it pretty quick. From memory around 19mm I think.
Hope this gives a little insight!
Mitch.
Last edited by mitchyboy01; Wednesday 24th December 2014 at 05:44. Reason: grammar
Grey 855R Manual. Totally standard.
mitch whats the diff between the hx and hy 35 turbos , been looking at 1 for the sierra
The HY's generally have a smaller turbine housing so will spool quicker but also begin to choke a lot sooner than the HX. the HY begins to lose efficiency after around 450bhp (depending on the application) whereas the HX will go quite a bit more. Both turbos spool very quickly for the power they produce. As the Holsets can come with a huge variation in housing sizes it's important to do your research and source the correct one for your application. I think a 12cm HX35 is one of the most popular for a road car but have also read good things about the 10cm HY35. Both turbos are awesome though IMO. I find driftworks is full of info about the Holsets if you want to do some good research.
leet5r (Thursday 25th December 2014)
