Results 1 to 12 of 12
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    Steering wheel judder when twizzling
    When I twizzle the steering wheel from lock to lock, when shunting into a parking space for example, the steering wheel judders. This occours when I am stationary or just crawling and only when I spin the steering quite quickly. If turn the wheel slowly it does not do it. It does not do it when I am rolling above 5mph, only when stationary or crawling. It's as if the pump can't keep up if I do it too quickly. Also seems to get better when car warms up.
    Checked PAS fluid level and is normal. Can't see any obvious leaks or problems.
    What do you think?
    '05 V70 T5 BTW
    Me: 2005 V70 2.4 T5 SE. All standard.
    The Wife: 2008 C70 2.5 T5 SE. All standard.
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Could be your PAS pump but I'd check your fluid levels first if you haven't already.
    Give me a high 6!!!
    Oct 2012
    221
    Fluid levels OK. Dunno how to check pump short of putting another one on and seeing if it cures it. Expensive way of trial and error!
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by silverhorse View Post
    What do you think?
    '05 V70 T5 BTW
    Mine does exactly the same m8, same symptoms and everything!
    It's not the pump, I've had this confirmed by a Volvo specialist master tech.
    First port of call is going to be a drain, flush and refill of the P/S fluid. That should sort it....if not, I'll be putting up with it cos a new rack is over £1000.
    I am inclined to believe that the previous owner may have topped up with the wrong fluid. P2 models should have LHM fluid and not the standard Dexron II or III found in most other makes. Mixing the fluid can have a big effect on steering and degrade the seals over time. Thankfully, mine does not leak so I know the seals are good.
    My flush is going to be in next few weeks, maybe just after Christmas. If you can hang on that long, I'll let you know if the issue is solved.
    I will also be buying the new, updated P/S reservoir as mine is the old version.
  5. The Following User Says Thank You to LeeT5 For This Useful Post:
    silverhorse (Wednesday 3rd December 2014)
  6. #5
    Give me a high 6!!!
    Oct 2012
    221
    Good man Lee! I feel a bit better now. Yep, I will wait for the outcome of your flush and see how we go.
    A grand for a steering rack
  7. #6
    Give me a high 6!!!
    Oct 2012
    221
    Done a PAS fluid flush. Problem solved! Glad about that bearing in mind the cost of a steering rack...
    Old fluid was black and gloopy. Definately needed changing.
  8. #7
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    That's excellent news! How did you do the flush?
  9. #8
    Give me a high 6!!!
    Oct 2012
    221
    Used the big syringe method. Got through a bottle and a quarter of new fluid before it was clean. Was trying to put up pics but photobucket is being an arse
  10. #9
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    So you sucked out all the old fluid from the reservoir then refilled with new fluid. Then you started the car and turned the steering lock to lock (how many times) and then sucked out all the fluid again and repeated.....??
    ....and you only used a 1.25 litres?
    I know it doesn't hold very much fluid but are you sure all your fluid is replaced and clean now?
    I was going to buy 5 Litres of LHM and suck it all out - refill, then drive the car for a day and repeat the same until I'd used all 5 litres. Can be bought cheap at Euros.
  11. #10
    Give me a high 6!!!
    Oct 2012
    221
    Quote Originally Posted by LeeT5 View Post
    No, ran it for a day then did it again.
    Yep Did the above 3 times. Nice and green now.
    How cheap? It was 15 quid a litre at Volvo........
  12. #11
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    The correct Volvo power steering fluid is Pentosin CHF 11S. Comma manufacture it.....
    Recommended by Comma for applications
    requiring:
    Density @ 20⁰C 0.827 g/cm3
    Viscosity @ 40⁰C 19 cSt
    Colour Green
    Viscosity @ -40⁰C 1050 cSt
    Viscosity Index 330
    Pour point ⁰C -54
    CHF11S* and CHF202*
    Part #
    VW/Audi G 002 000/TL52146;
    BMW 81.22.9.407.758;
    Opel B040.0070;
    Mercedes Benz 345.00;
    Porsche 000.043.203.33;
    Volvo 1161529-1
    MAN 3623/93 CHF11S;
    ISO 7308;
    DIN 51 524T2
    *CHF11S and CHF202 are registered trademarks of
    Pentosin-Werke GmbH'
    Shelf Life: 5 years
    Specially formulated, synthetic oil based hydraulic fluid for
    power steering, central hydraulic, suspension level
    control, stability and traction control systems.
    http://www.autosessive.com/res/image...rmal/CHF1L.jpg
    £9.59 a litre from S C Motor factors.
    Euro's don't do it, in fact they are useless and even list my car (by the reg) as having Dexron II.
  13. #12
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    I meant CHF
