Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 51
  1. #21
    Member
    Jan 2014
    0
    Quote Originally Posted by Ettienne View Post
    This Is the finished 740 ones 2 years ago
    looks great buddy
    did you do this on the t5 too
  2. #22
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Yep, I think there is some pics floating about but I was the first to use the renault brembo calipers.
    Ive done 2 types of brembo 4 pot on 350mm and various brembos on:
    Xc90 336mm
    Xc90 316s
    S60 320mm
    S60r 330s
    Rears 308s and 330s on brembo 4 pots or single pots including awd v70r p1s
    Quite literally most things, I don't use the 350s with 4 pots, as I keep cars looking standard, although one set does fit under Volans.
  3. #23
    Member
    Jan 2014
    0
    Xc90 336mm
    Xc90 316s
    S60 320mm
    S60r 330s
    whats the best four pots to use on the rears
  4. #24
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Porsche 4 pots fit well, actually Charlie's 854 t5r (my old car) has 4 pot fronts and rears on it (I forgot about that).
  5. #25
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Fronts
    Rears
  6. The Following User Says Thank You to oblark For This Useful Post:
    Ettienne (Sunday 30th November 2014)
  7. #26
    Member
    Jan 2014
    0
    Quote Originally Posted by oblark View Post
    Fronts
    Rears
    looks cool are you running the pegs on that car
  8. #27
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    17 pegs.
  9. #28
    Member
    Jan 2014
    0
    17 pegs.
    which car were they on
  10. #29
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Quote Originally Posted by dazbooker View Post
    didn't use Renault disc mate the discs are 320mm Volvo
    the wheel bolted on ok a bit close minds so may add 2mm spacer just to be sure
    It's not feesible to use the 320mm, you have to pull the caliper in from the edge, plus clearance issues are just too close (I find) to be safe.
    You should try a 316mm if you going to do it allows more clearance.
    But you've just said you may use a spacer, I'll dig out pics of the clearance with my set up I've got 10-12mm from the spokes or castings on the wheel, so more than enough to be a safe margin.
    The 350s I have made, (under Volans, no spacers etc) have similar clearance to your set up and I'm on the fence about using them due to clearance. Although I'll revisit that in the summer.
  11. #30
    Member
    Oct 2013
    Rotherham, South Yorkshire
    0
    Ive got Renault Brembo's and 320mm P2 discs. My wheels are 17" comets, everything is ready to fit, no idea how it will go though, Never did a dummy fit on the car.
    1997 V70R FWD Manual
    608 Modded ECU with Ostrich 2.0, COP Conversion, ITG Filter, 3.5" MAF, 3" intake, 18t turbo, Do88 Intercooler, RIP, 3" TB, 750cc EV14 injectors, AEM 320 Fuel Pump, 3" Cat back, Spartan2 Wideband
    Lowered 40mm, Poly Subframe inserts
  12. #31
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Quote Originally Posted by Avinitlarge View Post
    I doubt it will fit as I tried 7 and 7.5j comets before, but as always it's close just depending on if you want a safety margin / spacer etc.
    From what I remember they actually physically touch
  13. #32
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    I've just made some 320mm p2 large piston calipers fit under my 17 steelies on the 940 and accidentally made an adaptor bracket to allow running p2 brakes on it inc s60r 330s
    Worth noting its the same mounting pattern just different offset to the 850s, I'll offer it up when I get a minute
  14. #33
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Opps wrong thread
  15. #34
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Had an hour or so today, so hopefully fixed the clearance issue for 350mm brembo 4 pots under Volans (no spacer).
    Someone has my mock up hub so can't check until I buy a spare, but problem should be solved.
  16. #35
    Jul 2014
    Geelong, VIC, Australia
    4
    Renault Brembos under Titans look great!
    I'd be conscious of clearance with wheel weights though, personally, I wouldn't take to a caliper with a grinder or a file. If you need to do that, you're using the wrong caliper for the application.
    Pete's oem 320mm brakes are really neat too and are one of those unusual factory options that were fairly uncommon - probably less common even than the AP 5200 calipers and rotors that could have been opted for when new.
    The S40/V50T5 AWD & LS-LV Ford Focus ST conversion is a nice and simple conversion if, like me, you just really want to stay with a factory 17" wheel - if you can or want to go bigger, the options open up significantly.
    It's not the conversion you'd choose if your car is destined solely for track day duties - for that you'd use a 'real' 4 or 6 piston caliper, rather than a sliding type. It is however, a massive improvement over the 280mm and 302mm factory options and, with good pads and rotors, will be happy enough to do some track work.
    Here's a pic of the caliper and rotor mounted -
    Clearance with a 17" 'Propus C' wheel -
    Clearance with a 17" 'Titan' wheel -
    Stick-on weights located on the inside of the spokes will not clear, however they would if they were stuck on in the 'open area' between the spokes (though this would be fairly ugly) and an even better idea would be clamp-on/punch-on weights on the rear rim lip.
    For reference, here's how they fill out a 19" rim in comparison to the factory volvo options.
    280mm rotors with standard calipers. Aftermarket 19" wheel. C70 -
    302mm rotors with standard calipers. Aftermarket 19" wheel. C70 -
    320mm rotors with calipers sourced from LS-LV Ford Focus XR5 (ST to those of you in the UK). Aftermarket 19" wheel. C70 -
  17. #36
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    I just made up a bracket to use existing 850 caliper on 316s. Fits under titans etc will post up pics once I've fiddled a bit more.
  18. #37
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by AshDVS View Post
    Them wheels would look mint on my car with the 380mm rotors.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  19. The Following User Says Thank You to claymore For This Useful Post:
    Biff (Sunday 4th January 2015)
  20. #38
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Quote Originally Posted by claymore View Post
    I doubt they'd fit, they are big 380mm!
  21. #39
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    They fit under my Jag 19" wheels.
    PIC][/SIGPIC]
  22. #40
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Show off
