Um,, ok high beam fine, indicators fine , side lights fine,,
Dipped beam not working on both sides ?
Ive checked the fuses all seem ok?
Bulbs ok, but both lights out ,
Any ideas please
Ploppy
Any ideas please
Ploppy
If one xenon bulb was faulty could it make the other one not work?
Hi mate. No to your question above. Do you get a message on the dash? Car will tell you that a bulb has blown. The fact that both are not working suggests a relay. Hopefully something as cheap and easy as that, but knowing Volvo...............
And to answer your next question, no I don't know where relay is!!! Someone will be along shortly.
Me: 2005 V70 2.4 T5 SE. All standard.
The Wife: 2008 C70 2.5 T5 SE. All standard.
ploppy (Saturday 29th November 2014)
Has the shunt resistor overheated?
Not sure if the 2005 is the same as the 2001 but the relay and the often-problematic resistor are under a panel beneath the steering wheel, next to the OBD2 socket.
ploppy (Sunday 30th November 2014)
Just had a look in my book of words and pictures.
Is fuse no 16 ok in the central electronic module as that's does the Bi-Xenon on both sides..
No 16 fuse ok and power steering works too...
Ok,
just taken bumper off , etc, on closer inspection to the Xenon headlamps , I thought water was on the outside of the headlamps,,, wrong ,,, I feel yet again the ballasts are possibly wet on the inside yet again...
So have decided to order some non xenon headlamps as not going to order new ballasts only to get wet again.
lets hope this works !!
Yes changed one light already early last year when we had bad floods,
however now both dipped beam gone, water in both units , replaced with 2nd hand unit
Just hope valeo new halogen light units will work on this , Im sure they will
OK update,
just to let you know,
Both halogens fitted and work fine.
Ok getting local garage to adjust the beams as they seem to be very low and used interior headlamp switch ordered as they have the beam motors to raise or lower when towing as the xenon ones didnt have that option on the light switch,
Just need to somehow get rid of the message on the display saying HEAD LAMP FAILURE SERVICE REQUIRED although headlamps work fine !
Thanks all for your help
That could well be due to your new lamps having a lower electrical resistance compared to the xenons and ballasts. This will make your cars brain think there is a problem. You might have to put a couple of resistors in the circuit. Or the easy option is just to ignore it! Well done for getting them working though.
Thanks Silverhorse !
The plot thickens !
Ok went to local non volvo garage, very good I have to say
They found that every time lights turned on, head lamps would be forced to lowest beam position by motors ...
Ok so they disconnect headlamp motors at highest point and they are still to low for MOT standards ....
Ok , so have just emailed 3 Volvo dealers to see if they can plug into my volvo and update software to Halogen lights not Xenon !
Watch this space ...
Ploppy
Have you checked activation arm for head light level, its fixed to rear suspension, I had the bracket brake on mine with corrosion and so lights seemed to be looking at floor right in front of car all time, as soon as I fixed bracket it resolved the problem
Ex Police V70 T5 SE now scrapped.
Daily driver V60 D3 R-design
2004 C70 2.4T GT, modifications front strut brace, 19" Peg reps with white lettered tires.
I think from memory its on near side rear arm.
