Results 1 to 11 of 11
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    Intercooler Test results - standard T5 and S60R twin vs DO88
    Hi guys, here are some interesting data results comparing the standard Volvo p2 intercooler, S60R twin intercooler setup and the latest do88 performance version.
    the R twin intercooler shows very little benefit over the standard single Volvo intercooler on the outlet temp test.
    basically, the single do88 intercooler provides a massive improvement over both standard setups.
    it should be noted that when installing a do88 single intercooler to the R model , the smaller second intercooler is completely removed and the centre front grille is part of it, so the hole will need some mesh or similar putting into place to prevent damage from road debris or stones onto the new intercooler (and to look better!)
    discuss.........
    Jamie
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Well at least the silly litte intercooler does something quite impressive really.
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I think, as the last graph shows, it's not just extra cooling, but better airflow that's provided by the R set up.
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    I did mean birth, but surprising how much difference over the lesser t5
  5. #5
    Jul 2008
    126
    What was the ambient temp? LOL.
    The new IC looks great I must say.
  6. #6
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by Dream3r View Post
    Looking at the start temps I guess around 22 ?.
  7. #7
    Jul 2008
    126
    IATs are raised at idle, so I doubt it but you never know.
  8. #8
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Hopefully, when I eventually get my sodding VIDA/DICE working on my laptop, I'll be able to log my temps and post for comparison.
  9. #9
    Junior Member
    Apr 2010
    0
    i have a bulging stock intercooleron my 53 plate v70r awd so its a case of replace oem or go for a new system, can anyone advise which is easiest to install. do88 or ipd, im running a standard setup at present other than a upgraded airfiler and prins LPG system. Any advise please, im pretty handy but dont want to have to canabalise too much!
  10. #10
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    I can highly recommend a Tim Williams IC. Not cheap but is an absolute work of art, using a Swedish Core and hand made by a British engineering firm in the Midlands. Lead time is approx 4-6 aka depending on availability of the core.
    They are Front mount IC and use all original pipe work with no butchering required.
    You do need to remover the front bumper bar, but that's simple enough.
    I know this IC has been tested by Ashok and yeilded spectacular results with huge drops in IATs.
    You need to contact Tim Williams for more info or he'll be along shortly to add his pounds worth.
    Can't comment on the others but I would advise you do not buy cheap chinese cores.
    Knowing where the core comes from is vital. Cheap cores are prone to corrosion... apparently.
  11. #11
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Must say more than happy with my intercooler Tim did for me very little little trimming required.
    Also he didn't remove the front crash bar to fit it but did fit a new radiator as I had a small leak .
