Hi Folks,I bought one of Greame Welch full exhaust system's from a member on here month's ago as the existing one was blowing and I fancied a stainless one . I bottled out when it came to fitting it as it was for a front wheel drive V70 ph 2 and mine is a AWD I thought it maybe a PITA to fit. I left it in the garage for ages thinking about fitting it but not actually doing it anyway the existing exhaust started to blow more and more the wife keep pointing to the exhaust in the garage"why don't you fit that one ", well I made a start on it a couple of weeks ago and with the addition of a couple of 135o stainless bend's to make a 40mm set and reshaping the rear end [the pipe is oval under the rear diff] it went on quite easy, I think it sounds and looks brilliant the wife is not so sure .The car seems to go a lot better now but it could be my imagination just ordered a K&N panel air filter for the air box as I read on here that's the next thing to do. As you folks spend a lot of time tuning Volvo's could I ask if it was your car and you wanted to tune it a bit more [not too much as the wife mainly drive's it and I will never hear the last of it if I go to far ] what would you do next ?.
