Results 1 to 19 of 19
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    850 T5R serpentine belt and noises
    Right, I did a bit of searching but couldn't locate what I was after.
    The 'engine' makes a loud screeching noise (or a constant high pitch grumbling noise) when running regardless of revs used and we have been told that if the belt (serpentine?) is released or tension removed the noise stops. So when we come to remove the belt, how hard is it to replace all the ancillaries this feeds? I was looking at the idler pulley, PAS pump and alternator. The car has done over 300k so we'll be having the timing belt done as one of the first things anyway. We'll not do that but entrust this to someone that knows what they're doing.
    If this was done, I take it the serpentine belt has to come off anyhow, so it would be worth making sure the car was mechanically sound first before anything else is done.
    850T5R accept no substitutes
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    if you've got aircon the pump for that also runs off the same pump. Mine is totally different now so can't remember how they remove sorry
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    thanks for that, yes it has a/c and is a 94 model (I think) so the number shown, is that the part number?
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    http://www.gatesautocat.com/drive/VO...93_10-96/36597
    Note engine number, and maual or auto
  5. #5
    Lashing it up with binding
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    I'd say its probably the air-con pump making that noise but could be wrong, the tensioner is easy to replace and you can get them from volvo, i'd replace this regardless of condition. As for all the rest, it is abit of a job if you were to do it yourself. Merc85 sorted me out a brand new alternator and so far its been spot on and we do a few miles in our yoke.
  6. #6
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    many thanks, I'll double check the engine number. It's an auto.
    I also think you're right regards replaceing what you can, might as well if its all coming apart.
    The aircon doesn't work, it did but doesn't now so that could be the culprit, well I'm hoping it is
  7. #7
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    I`d put money on it being the idler wheel on the tensioner or the plastic idler wheel.
  8. #8
    Swede demon
    hemihusky's Avatar
    Jul 2014
    Bradford, West Yorkshire
    37
    i had a similar noise problem with mine and the screeching part turned out to be the idler on the tentioner being completely shot. the low grumbling i had on mine on occasion and after doing a timing belt change the noise seems to have gone. but i cant be sure as it was a very intermittent fault to begin with! is your noise like this? (Was recorded per-timing belt and tentioner change)
    https://www.dropbox.com/s/0onbb7p9tc...00920.mp4?dl=0
    The Scrapyard Saved 740
  9. #9
    JT's Avatar
    Jun 2010
    sussex
    1,641
    If the AC is not working, I'd say it was the pump trying to work without
    the gas in it.......
    At least that's what mine did
  10. #10
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by JT View Post
    If there's not gas in the system, the compressor shouldn't kick in, it'll just spin the pulley.
  11. The Following User Says Thank You to stribo For This Useful Post:
    merc85 (Wednesday 29th October 2014)
  12. #11
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    Quote Originally Posted by Andy G View Post
    If the noise is the a/c pump it will only be a worn bearing, that wouldn't cause it to stop working.
    If the ALT, PAS and A/C are all good, i'd just replace the idler, tensioner and belt with new genuine items and it will be spot on.
  13. #12
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Maybe you could post a video with the noise.....have you used a genuine oil filter...
  14. #13
    kyboy's Avatar
    Jul 2010
    Mansfield
    165
    I took my ac off and couldn't believe how much quieter mine was after!
  15. #14
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    cheers for the replies all, when its home I'll get a video shot, I haven't got the car with me.
  16. #15
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    Hemi, that's exactly what it sounds like, I have a video so will post it up shortly.
  17. #16
    Swede demon
    hemihusky's Avatar
    Jul 2014
    37
    Well on my case it was the serpentine belt idler. Does yours stop when the car warms up as mine did.
  18. #17
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    no the noise is constant on mine regardless of temp.
  19. #18
    Swede demon
    hemihusky's Avatar
    Jul 2014
    37
    i have one of those serpentine belt tools to make getting it off easy if you want to borrow it if you dont have one as i cant drive that far to you sadly (completely broke) but if its pretty close to my noise id say idler pulley as mine was absolutely shot
  20. #19
    T5R'ing
    Andy G's Avatar
    Mar 2005
    Cambs
    3
    could be ideal Hemi, I'll drop you a pm
