Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    massivewangers's Avatar
    Nov 2009
    Norwich
    14
    Quick Tips on What to look for - 850 T-5 - UPDATED WITH RESULTS!
    Been a good while since I've looked at one, and I'm viewing a T-5 in a couple of hours that has popped up local to me.
    It's low mileage and an auto. Any areas I should particularly look at? I've not sat in one for about five years!
    1996 850 T-5 -lowered 40mm, 17" Volans, T5-R front bumper and spoiler, recirc. blanked, open filter - GONE!
    2003 V70 D5 SE - very standard - ALSO GONE!
    2003 RenaultSport Clio 172 Cup - FOR SALE
    2016 VW Golf R DSG - GONE
    2013 Megane Renault Sport 265 - SOLD
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    it should boost to halfway into the white part of the gauge, pull dipstick out check for excess puffin' clunking noises from suspension, drop links, top mounts, brake hard if steering shakes probably wishbones need changing
  3. The Following User Says Thank You to T5frankie For This Useful Post:
    massivewangers (Thursday 16th October 2014)
  4. #3
    Nov 2013
    203
    Quote Originally Posted by T5frankie View Post
    What's the clunking? I've got that on mine.
  5. #4
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by Sweep View Post
    clunking on front at low speed turning? usually drop links, knocking/rattling at speed over bumpy ground usually top mounts
  6. #5
    Nov 2013
    203
    It's the latter for me, I'll be changing the springs soon so can get them done too. Is it worth going polyurethane?
    Sorry for clogging the thread, although I guess it helps a bit too!
  7. #6
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    i dont think you can get ploy top mounts mate
  8. #7
    Nov 2009
    Norwich
    14
    Thanks for the info. This is the car I saw, hopefully the link will work ok: http://m.ebay.co.uk/itm/251679658721?nav=SEARCH
    Sadly it wasn't really as nice as the ad suggests. The right rear arch was in primer with blobs of filler on it, the right front arch had been painted quite badly, the roof had lost quite a bit of lacquer, and the paint on the spoiler was very bad.
    The interior was fairly good, though there was what looked like a cigarette burn in the drivers seat, and the load cover was tatty.
    He did the driving, but the car appeared to pull ok and change gear well enough. There was a knocking from the left front. The top mount was shot but he had a replacement to fit. The radiator looked very new. After we'd been out, I was poking around under the bonnet and you could hear air escaping from the header tank. Perhaps I'm just being over-cautious, but it did raise a question in my mind.
    It looked an honest enough car, but the body work put me off as I'm not really looking to get involved with something like that. The hunt continues...
  9. #8
    Lashing it up with binding
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    I think you'll do well to find a T5 with good bodywork. Main points are rear main seal and power steering rack for leaks, both expensive, the rest is easy and only what you'd expect to do on cars of this age.
  10. The Following User Says Thank You to Saaamon For This Useful Post:
    massivewangers (Friday 17th October 2014)
  11. #9
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    O.K., am I in an alternative universe, or did Frankie actually post useful advise? At this rate JamesT5 will be part of the Mercedes F1 pit crew.
  12. #10
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    I usually leave the boring stuff to others to write
  13. #11
    Nov 2009
    Norwich
    14
    Quote Originally Posted by Saaamon View Post
    I don't expect it to be mint, they're all around twenty years old, so there's going to be bits here and there that aren't perfect, but there are limits.
    I think he probably should have mentioned the fact there was primer on one wheel arch in the ad, and that the roof needed paint at the very least. The listing suggests that the car is in mint condition. Even when I spoke to him on the phone he said that there was "just a scuff" on the rear arch, no mention of primer or filler, or the rust you could see underneath it for that matter.
    I'm sure someone will buy it, but it's not for me. I just didn't get that good feeling
  14. The Following User Says Thank You to massivewangers For This Useful Post:
    Saaamon (Friday 17th October 2014)
  15. #12
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    Quote Originally Posted by massivewangers View Post
    Looks like someone bought it. Is it me or are prices going up a tad?
    That's pretty expensive compared to some I've seen.
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
  16. #13
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Quote Originally Posted by Biff View Post
    That is a.500 quid car, prices ain't going up that much, I sold a decent 850 for 650 not long ago,
  17. #14
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    R's are definitely going up in price. But good 850s seem to not so much the v70s yet.
  18. #15
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    I thought it was Ilmor-Mercedes developed cars power plant,James specialist knowledge of turbos could be a real advantage for that team,he could get a call,but I guess he would have to go on gardening leave just to keep the other teams happy.....
  19. #16
    Nov 2009
    Norwich
    14
    Wish I could find a decent one for £650. Or £1000 for that matter...
  20. #17
    twine.
    Saaamon's Avatar
    Sep 2008
    Essex
    699
    I think 850 prices are going up.
  21. #18
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Just a waiting game I'm afraid got to watch the forums and get lucky,i've always bought forum car's you generally know where you stand with them, Frankie might be selling that teal r he has worth asking him
  22. #19
    Nov 2013
    203
    Took me a good 10 months to come across mine, and other than the common minor bubbling on the front wing, it's as clean as you like. A little more than I'd liked to of payed but I couldn't fault the condition.
  23. #20
    Nov 2009
    Norwich
    14
    Quote Originally Posted by Jamest5r View Post
    Just seen some pictures of that. It looks well on it's way to selling.
    I'm quite taken by the colour I must say!
