Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Member
    Mar 2014
    41
    940 solid flywheel conversion?
    Hi
    my humble 940 2.3 turbo has come a long way, haven't posted on here in a while, got all my planed mods done and am now driving daily to prove reliability before i spend much more.
    I'm now at the stage where with my new found power my clutch is slipping on speedy pull aways and will even drop out for a brief second and make the hole car judder briefly on top end high boost driving so am sourcing a stage 2 clutch with pressure plate and release bearing but have recently learn the car has a dual mass flywheel.
    i understand there are other solid flywheels i believe are made by volvo i can use but Im not sure which one(s) i can use, i have a m90 gear box that should be 20 splines and take a 240mm clutch so need something that will work with this.
    dose anybody have any ideas or done a conversion like this?
    thanks in advance you lovely people
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Ask Smithy he will know
  3. The Following User Says Thank You to Jamest5r For This Useful Post:
    chazz.stockham (Friday 10th October 2014)
  4. #3
    smithy's Avatar
    Apr 2006
    1,752
    J
    Quote Originally Posted by chazz.stockham View Post
    Hi
    Ttv flywheel and 850r clutch best combo in my opinion.
  5. The Following User Says Thank You to smithy For This Useful Post:
  6. #4
    Bird is the word!
    dionbullock's Avatar
    Aug 2008
    north wales
    92
    the 2.4td clutch kit is an easy upgrade for the lpt setup. Thats what ill be using in my 240 conversion
  7. The Following User Says Thank You to dionbullock For This Useful Post:
  8. #5
    smithy's Avatar
    Apr 2006
    1,752
    Quote Originally Posted by dionbullock View Post
    Yes but it is a 228mm clutch and dogfish flywheel .it all depends what power he is pushing and torque too .ive had both setups and killed the diesel clutch on the rollers lol.that was funny 300 bhp and good torque too .thats why I went for ttv flywheel and clutch .it all depends what setup he has .and future mods too .
  9. The Following User Says Thank You to smithy For This Useful Post:
  10. #6
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    I may know someone breaking a r-98 940 turbo, he is doing an engine conversion.
    I'll post up if he goes ahead, sorry for hijack but peeps who would be interested are reading this.
    Oh just curious why has nobody fitted the audi 4.2 v8, it's a straight fit.
  11. The Following User Says Thank You to Ettienne For This Useful Post:
  12. #7
    Bird is the word!
    Aug 2008
    north wales
    92
    Quote Originally Posted by Ettienne View Post
    Do tell... Straight swap?
  13. The Following User Says Thank You to dionbullock For This Useful Post:
  14. #8
    smithy's Avatar
    Apr 2006
    1,752
    They stick all kinds of v8s in 940 in the states .but in sweden mostly redblocks because they can get more power out of them and cheap to moddify too .
  15. The Following User Says Thank You to smithy For This Useful Post:
  16. #9
    Bird is the word!
    Aug 2008
    north wales
    92
    Quote Originally Posted by smithy View Post
    Ah i was thinking into a 240, not much different i suppose? But like you say, same ish power from a turbo redblock with a lot less cost involved. only a lack of thumping v8 noise
  17. The Following User Says Thank You to dionbullock For This Useful Post:
  18. #10
    Member
    Mar 2014
    41
    thank you for all your replies,
    Sorry for not replying sooner, i haven't been getting email updated as i should, excuse my ignorance but what is a Ttv flywheel and what vehicle would i try to source this from? and an 850r clutch is easy enough I'm guessing this takes 20 splines and is 240mm, so in theory i could use a upgraded clutch such as a black diamond stage 2, which is my intended clutch but would i but if i did do this would i buy it for the 940, 850 or to fit the Ttv flywheel or will they all be essentially the same?
    thanks again for the help, will try and keep you more updated with my work
    P.S. my goal is to in the end be aiming for around the 300hp mark as a daily driver as i do at the moment
  19. #11
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Ttv is a.company that makes custom lightened fly wheels to suit, not that expensive.
  20. The Following User Says Thank You to Jamest5r For This Useful Post:
    chazz.stockham (Thursday 16th October 2014)
  21. #12
    Member
    Mar 2014
    41
    thanks again, i have had a look at there website and found what i think to be the rite flywheel
    http://ttvracing.com/product/volvo-b...cturer=volcant see a price but have sent an enquiry form, looking at the details it takes (like standard) a 240mm clutch and is obviously 20 spline so in theory as long as i buy a clutch for a volvo with 20 spline 240mm it will fit, looking on a few websites prices range wildly even though they have the same splines and same diameter... surly one is the same as the next? or am i going overkill by looking at up-rated performance clutches baring in mind the hp i am ultimately amazing for and that its not going to be driven sensibly
    this is one of the best forums ive ever joined i really appreciate all the amazing help what a great community
  22. #13
    Member
    Mar 2014
    41
    Ive had response from TTV and they have given me details of the flywheel i need to use the 850r clutch, Im told that i will 'need' to either space the pivot ball by 5mm or make a 20mm longer slave cylinder push rod, can anybody tell me how i would go about doing either of these, pictures would be very helpful, when looking for an 850r clutch provided its being sold to fit a 850r with 20 splines and a diameter of 240mm i should be fine correct?
    thanks in advance
  23. #14
    smithy's Avatar
    Apr 2006
    1,752
    Best thing to do is extend the slave cylinder rod and even better make it adjustable .cut the rod in half and put a threaded bar in between the 2 ends .with 2 lock nuts
  24. The Following 2 Users Say Thank You to smithy For This Useful Post:
    chazz.stockham (Thursday 16th October 2014),jks (Thursday 16th October 2014)
  25. #15
    Member
    Mar 2014
    41
    excellent thank you, is this relatively easy or will there be any welding required to join the threaded rod, if you get time or have the facility to post a picture it would be much appreciated but if not no worried, the help has already been amazing, thanks again
  26. #16
    Våga Vägra 16V
    jks's Avatar
    Dec 2011
    costa del midlands
    17
    I've got all the parts in the shed, il get pics for you..
  27. The Following User Says Thank You to jks For This Useful Post:
    chazz.stockham (Friday 17th October 2014)
  28. #17
    Member
    Mar 2014
    41
    thanks a lot, really appreciate it cheers
  29. #18
    Våga Vägra 16V
    jks's Avatar
    Dec 2011
    costa del midlands
    17
    Sorry, forgot to post pics of modified slave cylinder arm, here You go..
    Sorry for crap phone pics, but it gives You idea..
  30. The Following User Says Thank You to jks For This Useful Post:
    chazz.stockham (Thursday 30th October 2014)
  31. #19
    Våga Vägra 16V
    jks's Avatar
    Dec 2011
    costa del midlands
    17
    Some of the stuff I've used,
    TTV flywheel with paddle,
    machined dogdish flywheel with 850R clutch,
    Depends what you after and how you drive it..
  32. The Following User Says Thank You to jks For This Useful Post:
  33. #20
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Oh sorry yes apparently from what I've heard the audi lump meets straight up to the diesel box originally a vag box
  34. The Following User Says Thank You to Ettienne For This Useful Post:
