Hi all I need to know if a rip kit of a 850 t5 will fit my s70r manual cheers I was worried about the hose going onto the turbo as I know mine has a larger turbo then a 850 cheers
I don't see why it should not fit, as you say your turbo is larger, you may need a different reducer/adaptor for that bit, easily available from someone like Ash silicone hoses
polak t5r (Thursday 18th September 2014)
Cool thanks does anyone know what size adapter id need
The hose that goes on the turbo is normally bigger anyway so there's a bit of slack, on the aftermarket kits, don't know about the Volvo one, but I suppose you could use the hose that's already there.
Cool ill have to have a play and see what happens cheers
the first question is whether the turbo's outlet pipe is larger than the standard one and what turbo is it ??
All td04's have the same size outlet
51mm iirc all the same.
The 12t has a different exhaust housing the rest are the same.
The 3" angle exhaust housing is different on the 12t as they have a smaller exhaust turbine wheel. So the hit side is different on the 12t, but that's the only one that is.
it has the standard s70r manual turbo on is it 18t
Assuming that both are stock and havent been fitted with non-volvo or aftermarket turbos, there should be no issue at all.
