my `96 t5 uses this type of remote
question is can I use this type of remote?
this is how the car looks now with her new 17" wheels from ebay £10.60 for the set with good tyres....cant go wrong
Purple `95 855 t5 auto, MBC (13psi), boost gauge, cold air induction kit. I luv my purple bus...
hi jim, I don't think you can use the 2 button type.
there are actually 2 versions of the correct 850 one, 413 mhz, and 433mhz.
you normally use a remote tester to find out which as vida is not always accurate especially if it was fitted as an accessory kit.
From research that I did it seems the alarm with the glass sensor of the driver a pillar requires the bottom remote. I'm on the lookout for one.
It's a 5 Cylinder Orchestra!
one type is for a guard 1 alarm and the other for a guard 2 .
they are different systems.
the second having a scrolling codes with over 1000 variants.
i have two of the first type both in great condition for grabs........
1995 854 t5r
Ok so here goes.
I took delivery of 2 remotes same as in the top picture, changed the batteries for new ones,went through the programming proceure and neither of them will program to my car?
Any thoughts?
Im thinking maybe my car is an import or something and might be worth checking its VIN to find out where it was built as not all remotes/cars are compatible depending on market etc?........
