Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 104
Thread: Project ME7
  1. #21
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by S70T5Chris View Post
    From the factory, I do believe the ME7 head does flow a 'little bit better' than the Pre-ME7's. But if you're going to the hassle of building an engine, surely you'd port and flow the cylinder head anyway.
    As DR, my 850 will be having an S60R bottom end and an 850 head.
    Valve stems are a lot thinner, so flow a lot better.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  2. #22
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by Ettienne View Post
    The heads are interchangeable, the me7 iirc flows approx 30% better with its smaller valve stems and it's reshaped valve / inlet area, also the me7 has 2.5 kg lighter crank, so less rotating mass making the engine rev easier.
    Plus you can use coil packs on the 850 and there are attachments for them on the me7 head and depending on which engine you use it may be semi forged / uprated.
    So taking that into account, then it's a no brainer as a small mod the the vvt cam pulley and that's it (dependant on engine) no need to take the head off, the Americans have been doing it for years.
    Another advantage is the oil cooler on the sump meaning you can run a larger radiator, with out oil cooler for the engine, which can be upgraded to a d5 version.
    I see no need to use an 850 head at all, several Americans are well in excess of 400 with this set up.
    And some British as well
    PIC][/SIGPIC]
  3. The Following User Says Thank You to claymore For This Useful Post:
    Ettienne (Sunday 24th August 2014)
  4. #23
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    Quote Originally Posted by claymore View Post
    Sorry mate forgot you lol
  5. #24
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,985
    i wouldnt fit that me7 engine mate, Its not clean enough lol How's the wheel bolts coming on anyway?? lol
  6. #25
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by merc85 View Post
    He's going to start a thread on detailing an engine block soon.
  7. #26
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    That sir, is something you will never see
    PIC][/SIGPIC]
  8. The Following 2 Users Say Thank You to claymore For This Useful Post:
    Jamest5r (Sunday 24th August 2014),stribo (Sunday 24th August 2014)
  9. #27
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Good, we have enough detailing threads as it is.
  10. The Following User Says Thank You to stribo For This Useful Post:
    p fandango (Monday 25th August 2014)
  11. #28
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The ME7 head definitely flows much better.
    Putting a 850 head on a ME7 block seems the wrong way around to me.
    The yanks are years ahead of us on modifly and fitting ME7 engines into 850`s
    I`m going to do a cold compression test on the engine tomorrow,
    If the compression is 100 psi + then the head will removed liners shimmed and forged rods fitted.
    In the end I`ll end with a fully forged engine (rods + pistons )
  12. #29
    Now in an Audi...to allow more
    time for my 850s lol
    Shinsplintz 101's Avatar
    Nov 2013
    Baldock, Hertfordshire
    356
    Not to sound like a numpty - but I've got a 2.3 ME7 lump from an '02 T5 - do I just need to blank the VVT solenoids & I'm away for a straight swap into the 850?? Was my understanding it was a bit more complicated than that - will do a bit of research on the US forums. What are the advantages of the later 2.3 lump? Any help gratefully appreciated, Cheers, Morgan
    p.s I have always enjoyed reading your engine threads - just way over my payscale to make any useful contribution. Keep em coming though!
  13. #30
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by Shinsplintz 101 View Post
    Good thread here...
    http://volvospeed.com/vs_forum/topic...-n-whiteblock/
  14. The Following 2 Users Say Thank You to jamesy12345 For This Useful Post:
    Shinsplintz 101 (Monday 25th August 2014),WOODY T5 (Monday 25th August 2014)
  15. #31
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    You have a PM
  16. The Following User Says Thank You to oblark For This Useful Post:
  17. #32
    Member
    Oct 2013
    Rotherham, South Yorkshire
    0
    I bought a ME7 R engine from TC. I was going to use the bottom end from that, Use My M4.4 R head and have it ported then use N/A cams.
    The ME7 engine in a 1999/2000 comes in 2 formats, hydraulic lifters with 6mm valves, and solid shimmed lifters with 7mm valves.
    Going on the number of the engine I've got, it uses the same valves and lifters and the 4.4 head.
    By the look of your rocker cover, You have the 7mm valves with solid lifters. I hate faffing shimming solid lifters, Fit everything, measure gaps, re-shim. I did a couple of late Zetec engines that used shimmed lifters, the were pretty straight forward as the cam caps were not parts of the rocker cover.
    I don't know what to do with mine.
    1997 V70R FWD Manual
    608 Modded ECU with Ostrich 2.0, COP Conversion, ITG Filter, 3.5" MAF, 3" intake, 18t turbo, Do88 Intercooler, RIP, 3" TB, 750cc EV14 injectors, AEM 320 Fuel Pump, 3" Cat back, Spartan2 Wideband
    Lowered 40mm, Poly Subframe inserts
  18. #33
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by Avinitlarge View Post
    I don't know what to do.
    I thought the hydraulic lifters came with the 7 mm valve stems...
    Speaking from my own experience of a ported M4.4 head (on original 2.3 block) with N/A cams, the porting & higher lift doesn't make a massive difference but does complement other mods. I do need to adjust the cam timing tho.
    If you are going for massive power then it's worth researching but I would leave the ME7 head on & cams in, unless you can't live with the VVT for some reason
  19. #34
    Feb 2012
    135
    Quote Originally Posted by jamesy12345 View Post
    It does!
    Also solid lifters and 6mm valves are always VVT whatever but if you are hydraulic .......the hydraulic bucket from after autumn `97 is the improved one which empties the oil quicker to give a snappier valve shut......
    So if your mixing heads don`t use the earlier lifter from the 850T5 use the one from The B5234T3 onwards......
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  20. The Following User Says Thank You to 960kg For This Useful Post:
    jamesy12345 (Monday 25th August 2014)
  21. #35
    Member
    Oct 2013
    0
    Sorry, Got my numbers mixed up, Being doped up with pain killers has mashed my head
    hydraulic lifters with 7mm valves, and solid shimmed lifters with 6mm valves.
    1397641 M4.4 & early ME7 7mm inlet
    9454607 ME7 6mm inlet
  22. #36
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    I`ve had a very productive day out in the garage working on the ME7 engine.
    First thing I did was fit a old M56 gearbox so I could do a cold compression test, 120 psi balanced
    Then the head was removed so I could fit my forged rods.
    Here is a photo of a V70R rod (leftt) next to a standard 850 rod.
    And for those who have asked here is a photo of ME7 non VVT cam (left) a standard 850 cam (middle) and a ME7 VVT cam.
    I `ve removed the VVT pulley, I`ll be measuring it up and doing a drawing so I can get a new one made.
  23. The Following User Says Thank You to oblark For This Useful Post:
    craigoodwood (Monday 25th August 2014)
  24. #37
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by oblark View Post
    so are the rods the same, they look identical to me
  25. #38
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    To me they look identical the only way I tell them apart is V70R ones are oily
  26. The Following User Says Thank You to oblark For This Useful Post:
  27. #39
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by p fandango View Post
    they look pretty similar, is the one on the left wider (from a 2.4 phase 3 V70R engine I think)?
    Last edited by jamesy12345; Monday 25th August 2014 at 16:48. Reason: need L and R on my wellies
  28. #40
    Feb 2012
    135
    It is not so much what they look like but the process in production involved or manufacturing them!..........also the part number will be different...
  29. The Following 2 Users Say Thank You to 960kg For This Useful Post:
    Ettienne (Monday 25th August 2014),oblark (Monday 25th August 2014)
