Results 1 to 18 of 18
Thread: TT USB Problem
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    TT USB Problem
    Ok, not sure what I can do about this, but my second ECU (which has always been suspect) has a problem, I took out the fuel rail to see why it over fuels, and there is a constant spray out of injector three, as soon as you unplug the injector the flow stops, plug it back in and the flow starts, even with the ignition off as long as there is pressure in the rail it injects, any thoughts from the ECU Gurus?
    No wonder we couldn't get the afr's right on Paul's car.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
    Sep 2005
    Truro, Cornwall
    168
    is it worth trying your other ecu just to make sure its not a wiring issue? and plug the harness onto another injector just to rule everything else out? sorry you may have done all this but I always start with the basics back to the bigger more expensive possibilities
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Call Adam
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Jamest5r View Post
    Call Adam
    i've heard Adam's sold up
  5. #5
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Yep, runs fine on the front engine ecu, and yes I tried another injector and it does the same.
    PIC][/SIGPIC]
  6. #6
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Quote Originally Posted by p fandango View Post
    He has to the Yank distributor, but im sure he hasn't forgotten everything he developed lol
  7. #7
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Does he still pop on here?
    PIC][/SIGPIC]
  8. #8
    JT's Avatar
    Jun 2010
    sussex
    1,641
    my spare TT needs flashing evertime I try to use it
    stupid question, but you have flashed it??
  9. #9
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    No, how do you do that?
    PIC][/SIGPIC]
  10. #10
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Quote Originally Posted by claymore View Post
    Im sure he means just uploading the map each time
  11. #11
    JT's Avatar
    Jun 2010
    sussex
    1,641
    yea, upload 1 of the standard maps
  12. #12
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by JT View Post
    Yep tried all that in the past.
    PIC][/SIGPIC]
  13. #13
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    If the fault follows the ECU it couldn`t be a wiring fault and if you have uploaded new files it`s not a software fault.
    It looks more and likely the fault is inside the ecu with the PCB
  14. #14
    JT's Avatar
    Jun 2010
    sussex
    1,641
    and if youve tried your other TT and thats fine, must be a software issue,
    which is way over my head lol
  15. #15
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    It didn't work in my car, but, it 'apparently' worked in the car of the person I bought it off.
  16. The Following User Says Thank You to Volvostorm For This Useful Post:
    claymore (Tuesday 19th August 2014)
  17. #16
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by oblark View Post
    Exactly my thoughts.
    PIC][/SIGPIC]
  18. #17
    JT's Avatar
    Jun 2010
    sussex
    1,641
    yea, what rob said!
    told you it was over my head
  19. #18
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    I'd try and trace it back through the ecu, possibly one of the injector transistors... I'll have to get my broken ecu out to see if I can identify which one it is. From the wiring diagram injector 3 goes to pin A24 on the ecu. I'll see what I can find.
