Anyone changed a recirc valve on k24 turbo and what did you use?I`m suspecting mine is not doing the job as I can hear a funny noise on the boost and only boosting 15-16psi with MTE stage1 map.Also what boost should you have from MTE stage 1?I blocked the recirc valve pipe and the boost is now about 14psi.Looks like its a turbo off job on these the remove it.
