Hi,
I have a 2011 S80 D5 which runs fine.
Except for an intermittent potentially dangerous problem with the throttle. Occasionally there is no response at all from the accelerator.
There doesn't seem any pattern to it, hot or cold engine, hot or cold weather are the same.
A typical example is coming up to a T junction close to where I live, it is on a slight hill. You often have to wait for a gap in the traffic and when you get one you have nothing !!!
Pumping the pedal several times seems to bring it back but it can lead to some very dangerous situations. I have sort of grown used to being prepared for it but it still catches you out, sometimes at roundabouts, it also happens whilst the car is in motion, not necessarily pulling away from a standstill.
It was in for service at the local Volvo dealer on Anglesey a few weeks ago but they said they couldn't replicate the fault. I also pointed out an intermittant problem with the driver's seat belt not pulling out, but they couldn't fix that either.
Having done some research I discovered that the seat belt problem was a loose connection under the drivers seat, and had been the subject of a recall on several models.
They said they updated the car's software and it did feel as though the throttle problem was better but it is actually just the same as it was before. I took the car to Le Mans and we had several very dicey moments!!
Apologies for the long posting, I am not sure how to describe it properly?
Any comments would be appreciated, thanks,
Martin
