Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Converting OBD1 too OBD2
    Is it possible to convert a OBD1 car to run a OBD2 ECU ?
    Is it just a case of removing the OBD1 flashing light box and fitting a OBD2 socket ?
    Or is it a little more complex than that ?
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Ahh, you have the same problem as me!
    I'm going to be fitting mine next weekend
    You need an OBD2 port (Got mine out of a vectra, need to move a few wires)
    3 wires - Live, earth and signal
    http://m44.wikia.com/wiki/Special:Ne...orschamtic.jpg
    Pin 4 - Earth
    Pin 16 - Live
    Pin 7 - To pin B36 on the ECU
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    So is that all is needed to get a obd2 socket working in a obd1 car?
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    As far as I can tell, yes.
    I've yet to do it though, its a project for next year
  5. The Following User Says Thank You to Volvostorm For This Useful Post:
    t5 pete (Wednesday 19th November 2014)
  6. #5
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Thank you Paul I will post how it goes
  7. #6
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Is 4.3 different to 4.4 as there are more than 3 wires going to the socket
  8. #7
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    You only need 3 leads on the obd2 socket, live, earth and the k-line to use a m4.4.
  9. #8
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Dont want it for 4.4 tho after spaked to bomb the other wires are for abs etc so I assume I could connect them to the wires leading to the obd1 port I the engine bay and get them to work I may try it but only need the obd2 port for data
  10. #9
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Hopefully in a couple of days I will get chance to try this I've got a socket from another Volvo and also got the ecu connectors so I can rob a pin.
    I don't know if there's different colour wires on each model but pin b36 looks to be a purple and white wire but looking at the back of the obd2 socket there isn't a purple and white wire to pin 7 so weather it changes colour down the line for some reason I don't know.
    Hopefully it works and then I will be able to put a definite response on it working and what to do.
  11. #10
    phillyc2003's Avatar
    May 2013
    warrington
    14
    Was this a success?
  12. #11
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by phillyc2003 View Post
    Was this a success?
    If it's just for reading the codes, you don't even need the obd port, just wire in a switch and push button.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  13. The Following User Says Thank You to claymore For This Useful Post:
    phillyc2003 (Sunday 6th December 2015)
  14. #12
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    Was this a success?
    Yes I got it all working fine and able to read live figures while mapping.
  15. The Following User Says Thank You to t5 pete For This Useful Post:
  16. #13
    May 2013
    warrington
    14
    Cheers lads . As for colin's input what had you done there as in whats it achive?
  17. #14
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Colin's setup reads the flash codes and allows you the reset them
  18. #15
    Junior Member
    Aug 2015
    Serbia
    0
    So, guys, i have m43 with a led diagnostic under the hood and you say i can make it obd2 and read it with for example an Androiod app ?
  19. #16
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    Quote Originally Posted by Chaki View Post
    Basically yes.
  20. #17
    Junior Member
    Aug 2015
    Serbia
    0
    Ok, thanks, it will help me, i want to follow whats happening with oil temperature during driving because i have no oil cooler on my t5 so i want to read the temp
  21. #18
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Neither the M4.3 or M4.4 ecu can read/monitor the oil temp.
  22. #19
    New Identity
    Dec 2006
    West Midlands
    2,491
    As above, on the 850 (or the p1 x70) there is only an oil pressure sensor which triggers when the pressure drops below a certain level.
    You would need to add an oil temp sensor and a gauge to monitor the oil temp.
  23. #20
    Junior Member
    Aug 2015
    Serbia
    0
    I did not know that...i will add the gauge then.
    But the rest will be fine for monitoring...
    Thanks!
