Page 7 of 7 FirstFirst ... 567
Results 121 to 128 of 128
  1. #121
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    I beg to differ, when I tried to do them on the C70 2 came off o.k., and 2 rounded off as the heads are quite soft. If you managed to get them all out in 1 piece then fair play to you.
    I just drowned them in PlusGas as I went and they came off, although they started to stiffen mid way through but this was just the surface rust on the protruding ends winding through the stub axle. I wouldn't say they were hard to remove, just a little effort.
    But this is why I purchased new bolts from the dealer rather than using the old ones. Interestingly, the Parts guy at my local Stealers told me that the workshop normally use all the old bolts except for the Driveshaft to Stub Axle ones. The only other exception would be if one did break or round off.
  2. #122
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by JamesT5 View Post
    No, I meant to day the bearing and assembly out of the stub axle.
    The ones I purchased didn't come with bolts.
    Not genuine then? Patent part!
    Contradicting yourself again I see.
  3. The Following User Says Thank You to LeeT5 For This Useful Post:
    claymore (Thursday 18th September 2014)
  4. #123
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by LeeT5 View Post
    No, I was referring to the MAF when I discussed genuine parts earlier. I've fitted pattern driveshafts to the S60, they come with a 2 year warranty and they're fine and at £50 they were also well priced.
    I'm not contradicting myself at all, Lee.
  5. #124
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    May I point you to a previous post of yours:
    I don't think the engine mounts are hydraulic mate, they're fixed. A CV joint will generally 'click click click' when it's worn whereas the wheel bearings tend to rumble which gets worse when you corner.
    My advice personally, is don't buy cheap parts if you can help it, especially wheel bearings. I'm not suggesting you were going to buy cheap parts but just in case. I've had the misfortune of seeing the cheaper parts fail prematurely (i.e. strut spring seats and ball joints), so I now fit OE Volvo or uprated parts to the car because they last longer and are better value in the long run (and hence I now replace rubber bushing with PU where possible). Also change both sides of the car because where one part has gone the other is probably not far behind.
    If you're doing the work yourself, I'd advice getting new bolts because the wheel bearing bolts are 'stretch bolts' so the thread can strip and they can snap and cause all sorts of issues. New bolts may come with the OE parts anyway but if not then I'd advise getting some.
    Ok, I hope that helps and good luck!
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  6. #125
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    Shovel and hole springs to mind lol
  7. #126
    VPCUK reigning car of the year
    Nealevo's Avatar
    Apr 2011
    Home for now.
    2,157
    Hes going to need a ladder...
  8. #127
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    luck!
    I think you missed to highlight a couple of bits there Colin
  9. #128
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Silence is Golden
